S32k358 Getting Burn
722件の閲覧回数
arun464
Could you please tell are the reaons  to cause MCD dameged or burn while Communicating with AFE.
695件の閲覧回数
PavelL
Hello @arun464 ,
There are several potential reasons why an MCU (such as S32K358) could be damaged or fail when communicating with an external Analog Front End (AFE):
  1. Voltage Level Mismatch
    • If the AFE uses different logic levels (e.g., 5 V) than the MCU (typically 3.3 V), direct connection without proper level shifting can cause overvoltage on MCU pins.
  2. Incorrect Power Sequencing
    • If the AFE powers up before the MCU or vice versa, signal lines may float or drive unexpected voltages, leading to latch-up or damage.
  3. Grounding Issues
    • Poor ground reference or ground loops can create voltage differences between devices, causing current surges through communication lines.
  4. ESD or EMI Events
    • Lack of proper ESD protection or shielding can result in transient voltages damaging the MCU I/O.
  5. Short Circuits or Miswiring
    • Incorrect pin mapping or accidental shorts during assembly can lead to permanent damage.
  6. Excessive Current on I/O Lines
    • Driving outputs against each other (bus contention) or incorrect pull-up/pull-down configuration can stress the pins.
To help us analyze further, could you please share:
  • The schematic of the MCU–AFE interface (including power rails and signal lines).
  • The AFE part number and communication protocol used (SPI, I²C, etc.).
  • Any observed conditions before failure (e.g., during power-up, under load).
This will allow us to provide more specific recommendations for protection and design improvements.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2250304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k358%20%E7%81%AB%E5%82%B7%E3%82%92%E8%B2%A0%E3%81%86%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EAFE%20%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E4%B8%AD%E3%81%AB%20MCD%20%E3%81%8C%E6%90%8D%E5%82%B7%E3%81%97%E3%81%9F%E3%82%8A%E7%84%BC%E6%90%8D%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k358%20Getting%20Burn%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250385%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F237965%22%20target%3D%22_blank%22%3E%40arun464%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%A4%96%E9%83%A8%E3%82%A2%E3%83%8A%E3%83%AD%E3%82%B0%20%E3%83%95%E3%83%AD%E3%83%B3%E3%83%88%20%E3%82%A8%E3%83%B3%E3%83%89%20(AFE)%20%E3%81%A8%E3%81%AE%E9%80%9A%E4%BF%A1%E6%99%82%E3%81%AB%20MCU%20(S32K358%20%E3%81%AA%E3%81%A9)%20%E3%81%8C%E6%90%8D%E5%82%B7%E3%81%97%E3%81%9F%E3%82%8A%E6%95%85%E9%9A%9C%E3%81%97%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EAFE%20%E3%81%8C%20MCU%20(%E9%80%9A%E5%B8%B8%E3%81%AF%203.3%20V)%20%E3%81%A8%E3%81%AF%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%20%E3%83%AC%E3%83%99%E3%83%AB%20(%E4%BE%8B%3A%205%20V)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E9%81%A9%E5%88%87%E3%81%AA%E3%83%AC%E3%83%99%E3%83%AB%20%E3%82%B7%E3%83%95%E3%83%88%E3%82%92%E8%A1%8C%E3%82%8F%E3%81%9A%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MCU%20%E3%83%94%E3%83%B3%E3%81%AB%E9%81%8E%E9%9B%BB%E5%9C%A7%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%20CAN%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E9%9B%BB%E6%BA%90%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%AE%E8%AA%A4%E3%82%8A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EAFE%20%E3%81%8C%20MCU%20%E3%82%88%E3%82%8A%E5%85%88%E3%81%AB%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%81%AE%E9%80%86%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E4%BF%A1%E5%8F%B7%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%8C%E6%B5%AE%E3%81%84%E3%81%9F%E3%82%8A%E4%BA%88%E6%9C%9F%E3%81%97%E3%81%AA%E3%81%84%E9%9B%BB%E5%9C%A7%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E3%80%81%E3%83%A9%E3%83%83%E3%83%81%E3%82%A2%E3%83%83%E3%83%97%E3%82%84%E6%90%8D%E5%82%B7%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E6%8E%A5%E5%9C%B0%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E6%8E%A5%E5%9C%B0%E5%9F%BA%E6%BA%96%E3%81%8C%E4%B8%8D%E5%8D%81%E5%88%86%E3%81%A7%E3%81%82%E3%81%A3%E3%81%9F%E3%82%8A%E3%80%81%E6%8E%A5%E5%9C%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E9%96%93%E3%81%AB%E9%9B%BB%E5%9C%A7%E5%B7%AE%E3%81%8C%E7%94%9F%E3%81%98%E3%80%81%E9%80%9A%E4%BF%A1%E5%9B%9E%E7%B7%9A%E3%81%AB%E9%9B%BB%E6%B5%81%E3%82%B5%E3%83%BC%E3%82%B8%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8BCAN%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3EESD%E3%81%BE%E3%81%9F%E3%81%AFEMI%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E9%81%A9%E5%88%87%E3%81%AA%20ESD%20%E4%BF%9D%E8%AD%B7%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%BC%E3%83%AB%E3%83%89%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E9%81%8E%E6%B8%A1%E9%9B%BB%E5%9C%A7%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20MCU%20I%2FO%20%E3%81%8C%E6%90%8D%E5%82%B7%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3E%E7%9F%AD%E7%B5%A1%E3%81%BE%E3%81%9F%E3%81%AF%E8%AA%A4%E9%85%8D%E7%B7%9A%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E3%83%94%E3%83%B3%E3%81%AE%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%8A%E3%80%81%E7%B5%84%E3%81%BF%E7%AB%8B%E3%81%A6%E4%B8%AD%E3%81%AB%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%88%E3%81%8C%E8%B5%B7%E3%81%93%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%B0%B8%E4%B9%85%E7%9A%84%E3%81%AA%E6%90%8D%E5%82%B7%E3%81%ABCAN%E3%81%A4%E3%81%AA%E3%81%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%3E%0A%3CP%3E%3CSTRONG%3EI%2FO%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E9%81%8E%E9%9B%BB%E6%B5%81%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%87%BA%E5%8A%9B%E3%82%92%E4%BA%92%E3%81%84%E3%81%AB%E9%A7%86%E5%8B%95%E3%81%99%E3%82%8B%20(%E3%83%90%E3%82%B9%E7%AB%B6%E5%90%88)%20%E3%81%8B%E3%80%81%E3%83%97%E3%83%AB%E3%82%A2%E3%83%83%E3%83%97%2F%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%80%81%E3%83%94%E3%83%B3%E3%81%AB%E3%82%B9%E3%83%88%E3%83%AC%E3%82%B9%E3%81%8C%E3%81%8B%E3%81%8B%E3%82%8B%20CAN%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E5%88%86%E6%9E%90%E3%82%92%E9%80%B2%E3%82%81%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EMCU-AFE%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%3CSTRONG%3E%E5%9B%9E%E8%B7%AF%E5%9B%B3%3C%2FSTRONG%3E(%E9%9B%BB%E6%BA%90%E3%83%AC%E3%83%BC%E3%83%AB%E3%81%A8%E4%BF%A1%E5%8F%B7%E7%B7%9A%E3%82%92%E5%90%AB%E3%82%80)%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%3CSTRONG%3EAFE%20%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%3C%2FSTRONG%3E%E3%81%A8%E9%80%9A%E4%BF%A1%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%20(SPI%E3%80%81I%C2%B2C%20%E3%81%AA%E3%81%A9)%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E9%9A%9C%E5%AE%B3%E7%99%BA%E7%94%9F%E5%89%8D%E3%81%AB%E8%A6%B3%E5%AF%9F%E3%81%95%E3%82%8C%E3%81%9F%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E7%8A%B6%E6%85%8B%20(%E4%BE%8B%3A%20%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E6%99%82%E3%80%81%E8%B2%A0%E8%8D%B7%E3%81%8C%E3%81%8B%E3%81%8B%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E3%81%8D)%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E4%BF%9D%E8%AD%B7%E3%81%A8%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E6%94%B9%E5%96%84%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%88%E3%82%8A%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AA%E6%8E%A8%E5%A5%A8%E4%BA%8B%E9%A0%85%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
