hi
We are working with the S32K324 controller. We have a Bootloader and an Application, and we wanted to know if we can upload the hex from the code flash and download a copy of the hex file to multiple boards.
It is rather question for debug probe providers. For instance following PeMicro SW in capable to upload MCU memory content into s19 file (S-record) and with this tool you can also erase the chip and program it:https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320181&productTab=5053
https://www.pemicro.com/support/index.cfm
With Lauterbach TRACE32 you will be able to achieve this functionality as well.
hi Davidtosenovjan,
Thanks for the reply.
Is it possible upload and download the hex file using JTAG Debugger
