S32k can autorecovery
已解决
跳至解决方案
2,216 次查看
uky746
HI.
TOOL : S32 Design Studio for s32 platform (3.3)
Board : S32K144EVB-Q100 (NXP)
Source : can_pal_s32K144  ("enable flexible data rate " uncheck)
i want that after a bus off the module recovery and restart in automatic, to receive and send the messages again.
test condition
step1. push "sw3"    (communication Succed)
step2. remove CAN Annalyzer   (CAN_H, CAN_L  = OPEN)
step3. continuous 10 count  push "sw3"
step4. Connect CAN Annalyzer    (communication fail)
step5. push "sw3"    (communication fail)
Add my project and Registers status
Could anyone help me to solve this problem?
标记 (1)
1 解答
2,204 次查看
Senlent
Hi@uky746
you can refer to this example to know more about the bus-off detected and recovery.
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K144-FlexCAN-TX-RX-Error-ISR-test-S32DS2...
this example posted by PetrS.
BR,
在原帖中查看解决方案
2 回复数
2,205 次查看
Senlent
Hi@uky746
BR,
2,188 次查看
uky746
Thanks for your support.!
