S32K3xx_RM
S32K3xx_RM
1,419件の閲覧回数
chuanlin
Hello, can this interrupt source of STM be turned off in debugging mode!!
1,403件の閲覧回数
Robin_Shen
The Ability to stop the timer in Debug mode mark with circle in your screenshot refers to: If CR[FRZ] = 1, STM stops the timer. Otherwise, when the timer is enabled (CR[TEN] = 1), the timer counts up continuously.
If the timer is stopped in debug mode, then its interrupt will not happen. Is this what you want to achieve?
Robin
