S32K3xx Non RAM
S32K3xx Non RAM
Kad
Hello, NXP engineer, does S32K396 support non-volatile RAM?
#S32K396
davidtosenovjan
If you mean whether there is some non-volatile RAM integrated on-chip, then answer is "No, it is not."
You may use EEPROM emulation driver running above data flash, to store non-volatile data.
Another option is using of external memory connected with QuadSPI interface. In your case suitable option can be MRAM:
https://www.everspin.com/
Kad
ok,thank you for answering my question.
