S32K396
S32K396
YY2410
单片机烧写了一版程序后,导致通过TJAG仿真器无法连接了,更换为MULTILINK仿真器同样无法连接,请教下怎么解决?仿真器连接报错如附件。
davidtosenovjan
Could you specify used environment? Where mentioned screenshot come from and what you did with the device before the failure?
%3CLINGO-SUB%20id%3D%22lingo-sub-2200611%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ES32K396%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200611%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20microcontroller%20burned%20a%20version%20of%20the%20program%2C%20resulting%20in%20the%20TJAG%20emulator%20can%20not%20be%20connected%2C%20replaced%20with%20MULTILINK%20emulator%20can%20not%20be%20connected%2C%20please%20tell%20how%20to%20solve%3F%20The%20emulator%20connection%20error%20is%20as%20attached.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2200696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K396%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2200696%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20specify%20used%20environment%3F%20Where%20mentioned%20screenshot%20come%20from%20and%20what%20you%20did%20with%20the%20device%20before%20the%20failure%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
