S32K396 flexio SPI example not working
Henrik-Wires
Cannot get the FlexIO SPI example Dspi_Flexio_Ip_Transfer_S32K396 to work. I have wired everything up as per the included description.txt but the FlexIO transaction never completes and the example is stuck at continiously checking Flexio_Spi_Ip_GetStatus().
Using Design Studio 3.6.3 (with 3.6.4 update) and RTD 6.0.0.
Henrik-Wires
Found the culpit. PTB28 is not wired to the MB by default on S32K396-BGA-DC1. Instead it is wired to the PHY connector.
Changing pinout to using PTF0-3 for LPSPI2 works much better.
And I am guessing this is also why the other example does not work as there is a lot of PHY pins not connected to the MB connectors.
It is almost as if you have selected pinouts to make life extra hard in using your tools.
Henrik-Wires
The other Spi_Transfer_S32K396 works, and is more closely aligned with what we are doing. So not a blocker for us.
Henrik-Wires
But not fully. Master do not receive data from slave. Will investigate further on monday.
Henrik-Wires
%3CLINGO-SUB%20id%3D%22lingo-sub-2261306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K396%20flexio%20SPI%20example%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECannot%20get%20the%20FlexIO%20SPI%20example%20Dspi_Flexio_Ip_Transfer_S32K396%20to%20work.%20I%20have%20wired%20everything%20up%20as%20per%20the%20included%20description.txt%20but%20the%20FlexIO%20transaction%20never%20completes%20and%20the%20example%20is%20stuck%20at%20continiously%20checking%26nbsp%3B%3CSPAN%3EFlexio_Spi_Ip_GetStatus%3C%2FSPAN%3E().%3C%2FP%3E%3CP%3EUsing%20Design%20Studio%203.6.3%20(with%203.6.4%20update)%20and%20RTD%206.0.0.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K396%20flexio%20SPI%20example%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFound%20the%20culpit.%20PTB28%20is%20not%20wired%20to%20the%20MB%20by%20default%20on%20S32K396-BGA-DC1.%20Instead%20it%20is%20wired%20to%20the%20PHY%20connector.%3CBR%20%2F%3E%3CBR%20%2F%3EChanging%20pinout%20to%20using%20PTF0-3%20for%20LPSPI2%20works%20much%20better.%3CBR%20%2F%3E%3CBR%20%2F%3EAnd%20I%20am%20guessing%20this%20is%20also%20why%20the%20other%20example%20does%20not%20work%20as%20there%20is%20a%20lot%20of%20PHY%20pins%20not%20connected%20to%20the%20MB%20connectors.%3CBR%20%2F%3E%3CBR%20%2F%3EIt%20is%20almost%20as%20if%20you%20have%20selected%20pinouts%20to%20make%20life%20extra%20hard%20in%20using%20your%20tools.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K396%20flexio%20SPI%20example%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261397%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EBut%20not%20fully.%20Master%20do%20not%20receive%20data%20from%20slave.%20Will%20investigate%20further%20on%20monday.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2261376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K396%20flexio%20SPI%20example%20not%20working%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20other%20Spi_Transfer_S32K396%20works%2C%20and%20is%20more%20closely%20aligned%20with%20what%20we%20are%20doing.%20So%20not%20a%20blocker%20for%20us.%3C%2FP%3E%3C%2FLINGO-BODY%3E
