S32K348-GPIO EIRQ to DMA request
1,830 次查看
OndrejK
Dear NXP Support Team,
I.m trying now approach, where GPIO PTD6 has setting as EIRQ14 ,rising edge detection and I want to map this pin signal to the DMA channel, where I try get current value from PIT_1 Timer[0]. This is setup as FreeRunning.
Seems that SIUL2 is set correctly for PTDA and I can see toggling on this pin when signal (1Hz) from signal generator is connect on related MCU pin.
But DMA not working for me
My guess here is that I have problem with finding proper chain from PTD6 ->DMAMUX-> DMA channel 4. and find where exactly I can find these information.
From S32K3xx_DMAMUX_map.xlsx I got this:
so here is my first issue: Which source->request  is dedicated for PTD6(EIRQ14) ?
And how is related Table 44 from RM manual?
 Here is fragments of my code which I working on now:
Setup PTD6
void Setup_PTD6_EIRQ14_for_DMA(void)
    /* 1. Configuration of physical pin PTD6 via MSCR register */
    // PTD6 corresponds to index MSCR[102] (as seen on your screenshot)
    IP_SIUL2->MSCR[102] = 0;              // Clear register
    IP_SIUL2->MSCR[102] |= (1 << 19);     // IBE = 1 (Input Buffer Enable - configures pin as input)
    IP_SIUL2->IMCR[542-(512)] = 3u;
    // Optional: if the signal floats, you can enable Pull-Up (PUE=1, PUS=1) or Pull-Down (PUE=1, PUS=0)
    /* 2. Activation of edge detection on line EIRQ[14] */
    // We want to capture the timestamp on every rising edge
    IP_SIUL2->IREER0 |= (1 << 14);        // IREER0[EIRE14] = 1 (Enable Rising Edge)
    IP_SIUL2->IFEER0 &= ~(1 << 14);       // IFEER0[EIRE14] = 0 (Disable Falling Edge)
    /* 3. Request routing: Change from Interrupt to DMA */
    // This step ensures that the edge does not wake up the CPU (NVIC), but triggers the DMA line instead
    IP_SIUL2->DIRSR0 |= (1 << 14);        // DIRSR0[DIRS14] = 1 (Select DMA Request instead of Interrupt)
    /* 4. Final enable of DMA request generation for EIRQ[14] */
    IP_SIUL2->DIRER0 |= (1 << 14);        // DIRER0[EIRE14] = 1 (Activate DMA request line)
and setup DMA channel:
void Setup_eDMA_Channel4_Capture_PIT1(void)
    /* 1. DMAMUX Initialization for eDMA Channel 4 */
    // Map EIRQ14 (source 14) to eDMA channel 4
    IP_DMAMUX_1->CHCFG[4] = DMAMUX_CHCFG_ENBL_MASK | DMAMUX_CHCFG_SOURCE(7u);  // EIRQ14 is source 7 for DMAMUX_1
    //IP_DMAMUX_0->CHCFG[4] = 0U;
    /* 2. TCD Configuration for Channel 4 pointing to PIT_1 (Exact S32K3 bare-metal syntax) */
    // Source: Current value of PIT_1 Timer 0
    IP_TCD->TCD4_SADDR = (uint32_t)&(IP_PIT_1->TIMER[0].CVAL);
    IP_TCD->TCD4_SOFF  = 0;       // Source does not increment
    IP_TCD->TCD4_ATTR  = 0x0202;  // 32-bit source, 32-bit destination
    // Minor Loop: Number of bytes transferred per single trigger
    // In S32K3 this corresponds to the NBYTES_MLOFFNO register (no minor loop linking)
    IP_TCD->NBYTES4.TCD4_NBYTES_MLOFFNO = 4;  // Transfer 4 bytes (32-bit) per trigger
    // Destination: Our array in RAM
    IP_TCD->TCD4_DADDR = (uint32_t)dma_timestamps;
    IP_TCD->TCD4_DOFF  = 4;       // Shift by 4 bytes in RAM after each edge
    // Circular buffer: wrap around to the beginning after filling the entire array
    IP_TCD->TCD4_DLAST_SGA = -(BUFFER_SIZE * 4);
    // Major Loop Counter: Total number of iterations in the loop
    //IP_TCD->CITTER4.TCD4_CITER_ELINKNO = BUFFER_SIZE;
    IP_TCD->CITER4.TCD4_CITER_ELINKNO = BUFFER_SIZE;
    IP_TCD->BITER4.TCD4_BITER_ELINKNO = BUFFER_SIZE;
    /* 3. eDMA channel activation for hardware triggers via official macro */
    //IP_TCD->CH4_CSR |= DMA_TCD_CH4_CSR_ERQ_MASK;
    /* 3. eDMA channel activation for hardware triggers (With asynchronous mode enabled) */
    // Bit 0 (ERQ) = 1  -> Enables hardware triggers
    // Bit 2 (EARQ) = 1 -> Enables asynchronous requests from external pins (SIUL2 EIRQ)
    IP_TCD->CH4_CSR |= 3u;  // ERQ=1, EARQ=1
Here I guess is key line:
where I'm little bit confused which IP_DMAMUX and which DMAMUX_CHCFG_SOURCE I need to use and where is proper information about this.
Ondrej
1,310 次查看
OndrejK
Hi SenLent,
finaly i found where is "issue" here.
Problem is that Ozone and Lauterbach just presenting different way od DMA_MUX->CHCFG and final trick is that these CHCFG register is mapped on MCU side (base adress for DMA_MUX_1 is 0x40284000) in this order:
0x40284000 ->CHCFG[3]
0x40284001  ->CHCFG[2]
0x40284002 ->CHCFG[1]
0x40284003 ->CHCFG[0]
0x40284004 ->CHCFG[7]
0x40284005 ->CHCFG[6]
0x40284006 ->CHCFG[5]
0x40284007 ->CHCFG[4]
0x40284008 ->CHCFG[11]
see my screenshot below
and from this moment my result give me sense and corresponding with your tips
Thank you for your support
and I guess that this ticked can be resolved
17 回复数
1,790 次查看
Senlent
Hi@OndrejK
Your understanding is correct:
PTD6->EIRQ14->DMAMUX1.SOURCE 7.
However, the TDC settings are incorrect.
My understanding is that they should be as follows:
IP_DMAMUX_1->CHCFG[0] ->TCD 16
IP_DMAMUX_1->CHCFG[4] -> TCD 20 instead of TCD4
1,787 次查看
OndrejK
Hi Senlent,
thank you for your answer.
please, can you pointed me from where popup your meaning about TCD mapping?
Is this meaning, that MCU have 32 TCD channels and TCD 0 to 15 is valid for DMAMUX_0 and TCD 15 to31 is
for DMAMUX_1 ?
So I'm still little bit confused about information regarding DMAMUX and eDMA.
Ondrej
标记 (3)
1,783 次查看
Senlent
Hi@OndrejK
"Is this meaning, that MCU have 32 TCD channels and TCD 0 to 15 is valid for DMAMUX_0 and TCD 15 to31 is for DMAMUX_1 ?"
yes, you can find these info in the datasheet, I copy it for your reference.
1,686 次查看
OndrejK
HI SenLent,
 I made some changes in my code based on my observation.
Here is my latest code:
main initialization:
    Setup_PTD6_EIRQ14_for_DMA();
    Setup_PIT1_Timer0_FreeRunning();
    Setup_DMAMUX_Channel0_ToTCD16_Capture_PIT1();
     //clear EIRQ14 interrupt flag
     IP_SIUL2->DISR0 = (1 << 14);
and here is rest of code:
    // 1. Aktivácia hodinového deliča pre filtre v SIUL2 (ak už nie je povolený inde)
    IP_SIUL2->IFCPR = 0U; // Nastavenie deličky filtra na Functional Clock (bez dodatočného delenia)
// 2. Voliteľne vypnite filter pre daný EIRQ index alebo ho nastavte na minimálny počet cyklov
// Pre EIRQ14 (v závislosti od mapovania registrov IFMCR):
    IP_SIUL2->IFMCR[14] = 0U; // 0U vypína digitálny filter, hrana prechádza okamžite ako čistý hardvérový trigger
void Setup_DMAMUX_Channel0_ToTCD16_Capture_PIT1(void)
   // Podľa NXP tabuľky prislúcha SIUL2 DMA request 4 zdrojový index 7u
    //IP_DMAMUX_1->CHCFG[4] = DMAMUX_CHCFG_ENBL_MASK | DMAMUX_CHCFG_SOURCE(7u);
    //follow doc ,first disable channel 4, then configure it, and finally enable it
    IP_DMAMUX_1->CHCFG[0] = 0u;
    IP_TCD->TCD16_SADDR = (uint32_t)&(IP_PIT_1->TIMER[0].CVAL);
    IP_TCD->TCD16_SOFF  = 0;       // Source does not increment
    IP_TCD->TCD16_ATTR  = 0x0202;  // 32-bit source, 32-bit destination
    IP_TCD->NBYTES16.TCD16_NBYTES_MLOFFNO = 4;  // Transfer 4 bytes (32-bit) per trigger
    IP_TCD->TCD16_DADDR = (uint32_t)dma_timestamps;
    IP_TCD->TCD16_DOFF  = 4;       // Shift by 4 bytes in RAM after each edge
    IP_TCD->TCD16_DLAST_SGA = -(BUFFER_SIZE * 4);
    //IP_TCD->CITTER20.TCD20_CITER_ELINKNO = BUFFER_SIZE;
    IP_TCD->CITER16.TCD16_CITER_ELINKNO = BUFFER_SIZE;
    IP_TCD->BITER16.TCD16_BITER_ELINKNO = BUFFER_SIZE;
    //IP_TCD->CH16_CSR |= 3u;  // ERQ=1, EARQ=1
    //enable DMAMUX channel 0
    IP_DMAMUX_1->CHCFG[0] = DMAMUX_CHCFG_ENBL_MASK | DMAMUX_CHCFG_SOURCE(6u);
    __asm volatile ("nop");
And I'm still not able fire up DMA transfer by EIRQ(14) when is this assert. On Debugger I can see flag appear when I change signal on MCU PTD6 pin .
Next I can start manually DMA transfer by TCD16_CSR START bit and on TCD channel CITTER value is decreased and value form PIT1_TIMER[0] is stored to my dma_timestamps array.
Btw: This should be defined in "normal" SRAM section. I had before set this to data_cache section , what lead to DMA "Destination bus error"
new definition:
__attribute__((aligned(32))) __attribute__((section(".mcal_data")))
uint32_t dma_timestamps[BUFFER_SIZE];
but If I skip manual START (need to be never set from beginning of code) and I change signal on PTD6 pin , DMA channel do nothing , CITTER register stay on initialize value.
Please, can you help identify where I have problem?
I still guess that I have issue with proper connection from PTD6-EIRQ(14) asserted flag to the TCD16 channel.
Maybe correct source for DMAMUX channel?
For DMAMUX1-CH[0] I tested all sources (1 to of SUIL2 instances listed on DMAMUX excel table, without any success , but here I'm not sure if my steps was correct too
1,668 次查看
Senlent
Hi@OndrejK
I've created a demo for your reference, using PTD6 to trigger DMA for a single data transfer.
It's based on S32K344 + RTD 7.0.1.
And I've tested it;
I can assure you that my understanding is correct.
For PTD6, the source should 7.
 IP_DMAMUX_1->CHCFG[0] = DMAMUX_CHCFG_ENBL_MASK | DMAMUX_CHCFG_SOURCE(7u);
1,626 次查看
OndrejK
Hi Senlent,
thank you very match for your example.
After some changes I have working example now. I attach my adjusted project , where was one important issue:
SIUL ICU with DMA req enabling  was set up before whole DMA TCD channel was fully configured. In that case TCD_SADDR and TCD_DADDR was empty(zero values) and after that enabling DMA req in SUIL leads to DMA error - "Source bus error" what bring me sense.
After change order of this initialization. example start working for me.
But I have still problem understand exact relation between DMAMUX channel and TCD channel.
You wrote that DMAMUX should by configured as CHCGF[0].
After downloading and starting app in our S32k344 custom development board i found that DMAMUX-CHCFG[3] is configured and exactly in code in function  Dma_Mux_Ip_Init_Privileged is  line which exactly lead to this configuration:
RegisterIndex = DMA_MUX_IP_GATE_OFFSET((pConfig->pChannelConfigArr[ChannelCount].Channel));
here is screenshot from lauterbach Trace32 debugger, where you can see final setup after all initialization steps:
In Design studio I have next configuration after updating RTD to 7.0.1:
is this correct and what does it mean that here  is  choice of 3 DMA Mux sources?
1,619 次查看
Senlent
Hi@OndrejK
Good to hear that.
This configuration tool may cause some confusion for developers who are just getting started.
For the S32K348, there is no DMAMUX_3; only DMAMUX_0 and DMAMUX_1 exist.
•For the S32K310, S32K311, and S32K312: DMAMUX_0 channels 0–5 and DMAMUX_1 channels 0–5 are mapped to eDMA Transfer Control Descriptor (TCD) 0–5 and eDMA Transfer Control Descriptor (TCD) 6–11, respectively. Programming of DMAMUX_0 channels 6–15 and DMAMUX_1 channels 6–15 is therefore not expected; however, if programmed, any access will result in either an error response for channels 8–15 or no error response for channels 6–7.
•For the remaining S32K3xx devices: DMAMUX_0 channels 0–15 and DMAMUX_1 channels 0–15 are mapped to eDMA Transfer Control Descriptors (TCDs) 0–15 and eDMA Transfer Control Descriptors (TCDs) 16–31, respectively.
The above is taken from the data sheet, and it is easy to understand:
The “DMA Hardware Channel” corresponds to the TCD number.
When you select DMA_CHANNEL_0 ~ DMA_CHANNEL_15, DMAMUX_0 is used by default;
when you select 16–31, DMAMUX_1 is used by default.
For example, in this topic, PTD6 corresponds to Source 7 of DMAMUX_1, so “DMA Hardware Channel” can be set to any value between DMA_CHANNEL_16 and DMA_CHANNEL_31.
Let’s take another example: if you select EIRQ 7 to trigger DMA, then “Dma Hardware Channel” can be set to any value between DMA_CHANNEL_0 and DMA_CHANNEL_15.
1,603 次查看
OndrejK
Hi SenLent,
about choosing DMA channel here was my imagine that I can choose freely one from related DMA_MUX groups
Meantime I tested other DMA_MUX <->TCD combination and on my side working only next one
 IP_DMAMUX_1->CHCFG[3] and TCD16.
I got try next others:
IP_DMAMUX_1->CHCFG[4] and TCD17.
IP_DMAMUX_1->CHCFG[0] and TCD16.
And please, why exactly only IP_DMAMUX_1->CHCFG[3] and TCD16. working ?
And  how is the relationship between IP_DMAMUX_1->CHCFG[xx] and TCDyy ?
1,580 次查看
Senlent
Hi@OndrejK
Here is the right order:
IP_DMAMUX_0>CHCFG[0] and TCD0.
IP_DMAMUX_0->CHCFG[1] and TCD1.
IP_DMAMUX_0->CHCFG[2] and TCD2.
IP_DMAMUX_0->CHCFG[3] and TCD3.
IP_DMAMUX_0->CHCFG[4] and TCD4.
IP_DMAMUX_0->CHCFG[5] and TCD5.
IP_DMAMUX_0->CHCFG[6] and TCD6.
IP_DMAMUX_0->CHCFG[7] and TCD7.
IP_DMAMUX_0->CHCFG[8] and TCD8.
IP_DMAMUX_0->CHCFG[9] and TCD9.
IP_DMAMUX_0->CHCFG[10] and TCD10.
IP_DMAMUX_0->CHCFG[11] and TCD11.
IP_DMAMUX_0->CHCFG[12] and TCD12.
IP_DMAMUX_0->CHCFG[13] and TCD13.
IP_DMAMUX_0->CHCFG[14] and TCD14.
IP_DMAMUX_0->CHCFG[15] and TCD15.
IP_DMAMUX_1->CHCFG[1] and TCD17.
IP_DMAMUX_1->CHCFG[2] and TCD18.
IP_DMAMUX_1->CHCFG[3] and TCD19.
IP_DMAMUX_1->CHCFG[4] and TCD20.
IP_DMAMUX_1->CHCFG[5] and TCD21.
IP_DMAMUX_1->CHCFG[6] and TCD22.
IP_DMAMUX_1->CHCFG[7] and TCD23.
IP_DMAMUX_1->CHCFG[8] and TCD24.
IP_DMAMUX_1->CHCFG[9] and TCD25.
IP_DMAMUX_1->CHCFG[10] and TCD26.
IP_DMAMUX_1->CHCFG[11] and TCD27.
IP_DMAMUX_1->CHCFG[12] and TCD28.
IP_DMAMUX_1->CHCFG[13] and TCD29.
IP_DMAMUX_1->CHCFG[14] and TCD30.
IP_DMAMUX_1->CHCFG[15] and TCD31.
1,438 次查看
OndrejK
Hi SenLent,
I made test on latest S32 DS project  and I added more DMA_MUX configurations.
Here is screenshot of my setup:
and here is result after download build code to our board:
As you can see, your described order for assigning DMA_MUX and TCD is not followed.
Is this same bug on RTD software or ?
1,434 次查看
Senlent
Hi@OndrejK
I can't see what the problem is. Could you explain it more clearly, or provide the complete test project so I can tell you where your doubts lie?
1,430 次查看
OndrejK
here is my project, just adjusted latest one which I attached before
I created 2 channel on DMA_MUX_0 as DMA_Channel_0 and DMA_Channel_1.
and for these channel is assigned DMA_MUX_0->CHCFG[3] and DMA-MUX_0-CHCFG[2].
Same "mixed" order you can see on DMA_MUX_1
1,424 次查看
Senlent
Hi@OndrejK
This is the demo you provided; I haven't made any modifications.
These are my test results.
1,417 次查看
OndrejK
Hi Senlent,
meantime I tested this same project with my other colleague , which use S32DS version 3.6.3 and Ozone debugger and his results is same as your.
Seems that you have right. but I'm completely out what's going on on my side?
1,415 次查看
Senlent
Hi@OndrejK
It's obvious that this might be related to the debugger you're using, or perhaps the version of the debugger.
1,311 次查看
OndrejK
Hi SenLent,
1,308 次查看
Senlent
Hi@OndrejK
Good, please click "ACCEPT AS SOLUTION" to close this topic.
%3CLINGO-SUB%20id%3D%22lingo-sub-2395830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K348-GPIO%20EIRQ%20%E5%88%B0%20DMA%20%E8%AF%B7%E6%B1%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395830%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%B0%8A%E6%95%AC%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E5%9B%A2%E9%98%9F%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E7%8E%B0%E5%9C%A8%E5%B0%9D%E8%AF%95%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E5%B0%86%20GPIO%20PTD6%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%20EIRQ14%EF%BC%8C%E4%B8%8A%E5%8D%87%E6%B2%BF%E6%A3%80%E6%B5%8B%EF%BC%8C%E6%88%91%E6%83%B3%E5%B0%86%E6%AD%A4%E5%BC%95%E8%84%9A%E4%BF%A1%E5%8F%B7%E6%98%A0%E5%B0%84%E5%88%B0%20DMA%20%E9%80%9A%E9%81%93%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BB%8E%20PIT_1%20Timer%5B0%5D%20%E8%8E%B7%E5%8F%96%E5%BD%93%E5%89%8D%E5%80%BC%E3%80%82%E8%BF%99%E6%98%AF%E8%87%AA%E7%94%B1%E5%A5%94%E8%B7%91%E6%A8%A1%E5%BC%8F%E3%80%82%3CBR%20%2F%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%20SIUL2%20%E5%B7%B2%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E4%B8%BA%20PTDA%EF%BC%8C%E5%BD%93%E4%BF%A1%E5%8F%B7%E5%8F%91%E7%94%9F%E5%99%A8%E5%8F%91%E5%87%BA%E7%9A%84%E4%BF%A1%E5%8F%B7%20(1Hz)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E7%9B%B8%E5%85%B3%E7%9A%84%20MCU%20%E5%BC%95%E8%84%9A%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E8%AF%A5%E5%BC%95%E8%84%9A%E5%88%87%E6%8D%A2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%BD%86%E6%98%AFDMA%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3CBR%20%2F%3E%E6%88%91%E7%9A%84%E7%8C%9C%E6%B5%8B%E6%98%AF%EF%BC%8C%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8E%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%8E%20PTD6%20-%26gt%3B%20DMAMUX%20-%26gt%3B%20DMA%20%E9%80%9A%E9%81%93%204%20%E7%9A%84%E6%AD%A3%E7%A1%AE%E9%93%BE%E8%B7%AF%EF%BC%8C%E4%B9%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E5%9C%A8%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%8E%20S32K3xx_DMAMUX_map.xlsx%20%E6%96%87%E4%BB%B6%E4%B8%AD%E6%88%91%E5%BE%97%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784190602227.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392448i537C2447C5347AD7%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_0-1784190602227.png%22%20alt%3D%22OndrejK_0-1784190602227.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%AC%AC%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%9A%E5%93%AA%E4%B8%AA%E6%BA%90-%26gt%3B%E8%AF%B7%E6%B1%82%E6%98%AF%E4%B8%93%E7%94%A8%E7%9A%84%20PTD6(EIRQ14)%EF%BC%9F%3CBR%20%2F%3ERM%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E8%A1%A844%E4%B8%8E%E6%AD%A4%E6%9C%89%E4%BD%95%E5%85%B3%E8%81%94%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784190821068.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392449i86D6C282096E5B65%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_1-1784190821068.png%22%20alt%3D%22OndrejK_1-1784190821068.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9B%AE%E5%89%8D%E6%AD%A3%E5%9C%A8%E7%BC%96%E5%86%99%E7%9A%84%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20PTD6%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESetup_PTD6_EIRQ14_for_DMA%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%201.%20%E9%80%9A%E8%BF%87%20MSCR%20%E5%AF%84%E5%AD%98%E5%99%A8%E9%85%8D%E7%BD%AE%E7%89%A9%E7%90%86%E5%BC%95%E8%84%9A%20PTD6%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20PTD6%20%E5%AF%B9%E5%BA%94%E4%BA%8E%E7%B4%A2%E5%BC%95%20MSCR%5B102%5D%EF%BC%88%E5%A6%82%E6%82%A8%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMSCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E102%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%B8%85%E9%99%A4%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMSCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E102%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E19%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IBE%20%3D%201%EF%BC%88%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E4%BD%BF%E8%83%BD%20-%20%E5%B0%86%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%BE%93%E5%85%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIMCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E542%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E512%3C%2FSPAN%3E%20%3CSPAN%3E)%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E3u%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%8F%AF%E9%80%89%EF%BC%9A%E5%A6%82%E6%9E%9C%E4%BF%A1%E5%8F%B7%E6%98%AF%E6%B5%AE%E5%8A%A8%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%EF%BC%88PUE%3D1%EF%BC%8CPUS%3D1%EF%BC%89%E6%88%96%E4%B8%8B%E6%8B%89%EF%BC%88PUE%3D1%EF%BC%8CPUS%3D0%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%202.%20%E6%BF%80%E6%B4%BB%20EIRQ%5B14%5D%20%E7%BA%BF%E4%B8%8A%E7%9A%84%E8%BE%B9%E7%BC%98%E6%A3%80%E6%B5%8B%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E6%8D%95%E8%8E%B7%E6%AF%8F%E4%B8%AA%E4%B8%8A%E5%8D%87%E6%B2%BF%E7%9A%84%E6%97%B6%E9%97%B4%E6%88%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIREER0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IREER0%5BEIRE14%5D%20%3D%201%20(%E5%90%AF%E7%94%A8%E4%B8%8A%E5%8D%87%E6%B2%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIFEER0%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E~%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IFEER0%5BEIRE14%5D%20%3D%200%20(%E7%A6%81%E7%94%A8%E4%B8%8B%E9%99%8D%E6%B2%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%203.%20%E8%AF%B7%E6%B1%82%E8%B7%AF%E7%94%B1%EF%BC%9A%E4%BB%8E%E4%B8%AD%E6%96%AD%E6%9B%B4%E6%94%B9%E4%B8%BA%20DMA%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%AD%A4%E6%AD%A5%E9%AA%A4%E7%A1%AE%E4%BF%9D%E8%BE%B9%E6%B2%BF%E4%B8%8D%E4%BC%9A%E5%94%A4%E9%86%92%20CPU%EF%BC%88NVIC%EF%BC%89%EF%BC%8C%E8%80%8C%E6%98%AF%E8%A7%A6%E5%8F%91%20DMA%20%E7%BA%BF%E8%B7%AF%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDIRSR0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20DIRSR0%5BDIRS14%5D%20%3D%201%20(%E9%80%89%E6%8B%A9%20DMA%20%E8%AF%B7%E6%B1%82%E8%80%8C%E4%B8%8D%E6%98%AF%E4%B8%AD%E6%96%AD)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%204.%20%E6%9C%80%E7%BB%88%E5%90%AF%E7%94%A8%20EIRQ%5B14%5D%20%E7%9A%84%20DMA%20%E8%AF%B7%E6%B1%82%E7%94%9F%E6%88%90%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDIRER0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20DIRER0%5BEIRE14%5D%20%3D%201%20(%E6%BF%80%E6%B4%BB%20DMA%20%E8%AF%B7%E6%B1%82%E7%BA%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E5%B9%B6%E5%BB%BA%E7%AB%8BDMA%E9%80%9A%E9%81%93%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESetup_eDMA_Channel4_Capture_PIT1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%201.%20eDMA%20%E9%80%9A%E9%81%93%204%20%E7%9A%84%20DMAMUX%20%E5%88%9D%E5%A7%8B%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%B0%86%20EIRQ14%EF%BC%88%E6%BA%90%2014%EF%BC%89%E6%98%A0%E5%B0%84%E5%88%B0%20eDMA%20%E9%80%9A%E9%81%93%204%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_DMAMUX_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHCFG%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_ENBL_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_SOURCE%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E7u%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20EIRQ14%20%E6%98%AF%20DMAMUX_1%20%E7%9A%84%E6%BA%90%207%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_DMAMUX_0-%26gt%3BCHCFG%5B4%5D%20%3D%200U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%202.%20%E9%80%9A%E9%81%93%204%20%E7%9A%84%20TCD%20%E9%85%8D%E7%BD%AE%E6%8C%87%E5%90%91%20PIT_1%EF%BC%88%E5%AE%8C%E5%85%A8%E7%AC%A6%E5%90%88%20S32K3%20%E8%A3%B8%E6%9C%BA%E8%AF%AD%E6%B3%95%EF%BC%89%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%9D%A5%E6%BA%90%EF%BC%9APIT_1%20%E5%AE%9A%E6%97%B6%E5%99%A8%200%20%E7%9A%84%E5%BD%93%E5%89%8D%E5%80%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_SADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EIP_PIT_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETIMER%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3ECVAL%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_SOFF%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%BA%90%E5%80%BC%E4%B8%8D%E9%80%92%E5%A2%9E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_ATTR%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x0202%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%2032%20%E4%BD%8D%E6%BA%90%EF%BC%8C32%20%E4%BD%8D%E7%9B%AE%E6%A0%87%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%AC%A1%E8%A6%81%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%AF%8F%E6%AC%A1%E8%A7%A6%E5%8F%91%E4%BC%A0%E8%BE%93%E7%9A%84%E5%AD%97%E8%8A%82%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%9C%A8%20S32K3%20%E4%B8%AD%EF%BC%8C%E8%BF%99%E5%AF%B9%E5%BA%94%E4%BA%8E%20NBYTES_MLOFFNO%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E6%97%A0%E6%AC%A1%E8%A6%81%E5%BE%AA%E7%8E%AF%E9%93%BE%E6%8E%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ENBYTES4%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_NBYTES_MLOFFNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%AF%8F%E6%AC%A1%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E4%BC%A0%E8%BE%93%204%20%E5%AD%97%E8%8A%82%EF%BC%8832%20%E4%BD%8D%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E7%9B%AE%E6%A0%87%E4%BD%8D%E7%BD%AE%EF%BC%9A%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E6%95%B0%E7%BB%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_DADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3Edma_timestamps%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_DOFF%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%AF%8F%E6%AC%A1%E8%BE%B9%E6%B2%BF%E7%A7%BB%E5%8A%A8%E5%90%8E%EF%BC%8CRAM%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%B7%A6%E7%A7%BB%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%BE%AA%E7%8E%AF%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%9A%E5%A1%AB%E5%85%85%E5%AE%8C%E6%95%B4%E4%B8%AA%E6%95%B0%E7%BB%84%E5%90%8E%E5%BE%AA%E7%8E%AF%E5%9B%9E%E5%88%B0%E6%95%B0%E7%BB%84%E5%BC%80%E5%A4%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_DLAST_SGA%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E4%B8%BB%E8%A6%81%E5%BE%AA%E7%8E%AF%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%9A%E5%BE%AA%E7%8E%AF%E4%B8%AD%E7%9A%84%E6%80%BB%E8%BF%AD%E4%BB%A3%E6%AC%A1%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_TCD-%26gt%3BCITTER4.TCD4_CITER_ELINKNO%20%3D%20BUFFER_SIZE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECITER4%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_CITER_ELINKNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EBITER4%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD4_BITER_ELINKNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%203.%20%E9%80%9A%E8%BF%87%E5%AE%98%E6%96%B9%E5%AE%8F%E6%BF%80%E6%B4%BB%E7%A1%AC%E4%BB%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%9A%84%20eDMA%20%E9%80%9A%E9%81%93%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_TCD-%26gt%3BCH4_CSR%20%7C%3D%20DMA_TCD_CH4_CSR_ERQ_MASK%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%203.%20%E7%A1%AC%E4%BB%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%9A%84%20eDMA%20%E9%80%9A%E9%81%93%E6%BF%80%E6%B4%BB%EF%BC%88%E5%90%AF%E7%94%A8%E5%BC%82%E6%AD%A5%E6%A8%A1%E5%BC%8F%EF%BC%89%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E4%BD%8D%200%20(ERQ)%20%3D%201%20-%26gt%3B%20%E5%90%AF%E7%94%A8%E7%A1%AC%E4%BB%B6%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E4%BD%8D%202%20(EARQ)%20%3D%201%20-%26gt%3B%20%E5%90%AF%E7%94%A8%E6%9D%A5%E8%87%AA%E5%A4%96%E9%83%A8%E5%BC%95%E8%84%9A%E7%9A%84%E5%BC%82%E6%AD%A5%E8%AF%B7%E6%B1%82%20(SIUL2%20EIRQ)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECH4_CSR%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E3u%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20ERQ%3D1%EF%BC%8CEARQ%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E6%88%91%E6%83%B3%E5%85%B3%E9%94%AE%E5%B0%B1%E5%9C%A8%E8%BF%99%E9%87%8C%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3EIP_DMAMUX_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHCFG%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_ENBL_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_SOURCE%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E7u%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20EIRQ14%20%E6%98%AF%20DMAMUX_1%20%E7%9A%84%E6%BA%90%207%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E6%9C%89%E7%82%B9%E5%9B%B0%E6%83%91%EF%BC%8C%E4%B8%8D%E7%9F%A5%E9%81%93%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E5%93%AA%E4%B8%AA%20IP_DMAMUX%20%E5%92%8C%E5%93%AA%E4%B8%AA%20DMAMUX_CHCFG_SOURCE%EF%BC%8C%E4%B9%9F%E4%B8%8D%E7%9F%A5%E9%81%93%E5%93%AA%E9%87%8C%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E7%9B%B8%E5%85%B3%E7%9A%84%E6%AD%A3%E7%A1%AE%E4%BF%A1%E6%81%AF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E7%BF%81%E5%BE%B7%E9%9B%B7%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396236%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E2%80%9C%3CSPAN%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80MCU%E6%9C%8932%E4%B8%AATCD%E9%80%9A%E9%81%93%EF%BC%8C%E5%85%B6%E4%B8%ADTCD%200%E5%88%B015%E5%AF%B9DMAMUX_0%E6%9C%89%E6%95%88%EF%BC%8CTCD%2015%E5%88%B031%3C%2FSPAN%3E%3CSPAN%3E%E5%AF%B9DMAMUX_1%E6%9C%89%E6%95%88%EF%BC%9F%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E4%B8%AD%E6%89%BE%E5%88%B0%EF%BC%8C%E6%88%91%E5%A4%8D%E5%88%B6%E4%B8%8B%E6%9D%A5%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1784272853624.png%22%20style%3D%22width%3A%20700px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392557iDAF0E1AFFC4C413D%2Fimage-dimensions%2F700x336%3Fv%3Dv2%22%20width%3D%22700%22%20height%3D%22336%22%20role%3D%22button%22%20title%3D%22Senlent_0-1784272853624.png%22%20alt%3D%22Senlent_0-1784272853624.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20Senlent%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A7%A3%E7%AD%94%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%90%A6%E6%8C%87%E5%87%BA%E6%82%A8%E6%89%80%E8%AF%B4%E7%9A%84TCD%E6%98%A0%E5%B0%84%E7%9A%84%E5%90%AB%E4%B9%89%E6%98%AF%E4%BB%8E%E5%93%AA%E9%87%8C%E4%BA%A7%E7%94%9F%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%EF%BC%8CMCU%20%E6%9C%89%2032%20%E4%B8%AA%20TCD%20%E9%80%9A%E9%81%93%EF%BC%8C%E5%85%B6%E4%B8%AD%20TCD%200%20%E5%88%B0%2015%20%E5%AF%B9%20DMAMUX_0%20%E6%9C%89%E6%95%88%EF%BC%8C%E8%80%8C%20TCD%2015%20%E5%88%B0%2031%20%E5%AF%B9%20DMAMUX_0%20%E6%97%A0%E6%95%88%EF%BC%9F%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%20DMAMUX_1%EF%BC%9F%3CBR%20%2F%3E%E6%89%80%E4%BB%A5%EF%BC%8C%E6%88%91%E5%AF%B9DMAMUX%E5%92%8CeDMA%E7%9A%84%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%E4%BB%8D%E7%84%B6%E6%9C%89%E4%BA%9B%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3CBR%20%2F%3E%E7%BF%81%E5%BE%B7%E9%9B%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396208%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CA%20href%3D%22mailto%3AHi%40OndrejK%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BD%A0%E5%A5%BD%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E4%BD%A0%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%9A%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EPTD6-%26gt%3BEIRQ14-%26gt%3BDMAMUX1.SOURCE%207.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B4%5D%20%3D%20DMAMUX_CHCFG_ENBL_MASK%20%7C%20DMAMUX_CHCFG_SOURCE(7u)%3B%20%20%2F%2F%20EIRQ14%20is%20source%207%20for%20DMAMUX_1%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8CTDC%20%E8%AE%BE%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%EF%BC%8C%E5%AE%83%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%0A%3CP%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B0%5D%20-%26gt%3BTCD%2016%3C%2FP%3E%0A%3CP%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B4%5D%20-%26gt%3B%20TCD%2020%20%E8%80%8C%E4%B8%8D%E6%98%AF%20TCD4%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397112%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20SenLent%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E6%A0%B9%E6%8D%AE%E8%A7%82%E5%AF%9F%E7%BB%93%E6%9E%9C%E5%AF%B9%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E4%BA%86%E4%B8%80%E4%BA%9B%E4%BF%AE%E6%94%B9%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%88%91%E6%9C%80%E6%96%B0%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%E4%B8%BB%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%9A%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3ESetup_PTD6_EIRQ14_for_DMA%3C%2FSPAN%3E%20%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3Esetup_PIT1_Timer0_FreeRunning%3C%2FSPAN%3E%20%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ESetup_DMAMUX_Channel0_ToTCD16_Capture_PIT1%3C%2FSPAN%3E%20%3CSPAN%3E()%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%B8%85%E9%99%A4%20EIRQ14%20%E4%B8%AD%E6%96%AD%E6%A0%87%E5%BF%97%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDISR0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%85%B6%E4%BD%99%E4%BB%A3%E7%A0%81%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESetup_PTD6_EIRQ14_for_DMA%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%201.%20Aktiv%C3%A1cia%20hodinov%C3%A9ho%20deli%C4%8Da%20pre%20filtre%20v%20SIUL2%20(ak%20u%C5%BE%20nie%20je%20povolen%C3%BD%20inde)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIFCPR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0U%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E5%8A%9F%E8%83%BD%E6%97%B6%E9%92%9F%E7%9A%84%20Nastavenie%20deli%C4%8Dky%20filtra%20(bez%20dodato%C4%8Dn%C3%A9ho%20delenia)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F%2F%202.%20Volite%C4%BEne%20vypnite%20%E8%BF%87%E6%BB%A4%E5%99%A8%E9%A2%84%20dan%C3%BD%20EIRQ%20%E7%B4%A2%E5%BC%95%20alebo%20ho%20nastavte%20na%20minim%C3%A1lny%20po%C4%8Det%20cyklov%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20Pre%20EIRQ14%EF%BC%88v%20z%C3%A1vislosti%20od%20mapovania%20registrov%20IFMCR%EF%BC%89%EF%BC%9A%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIFMCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0U%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%200U%20vyp%C3%ADna%20digital%C3%A1lny%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%8Chrana%20prech%C3%A1dza%20okam%C5%BEite%20ako%20%C4%8Dist%C3%BD%20Hardv%C3%A9rov%C3%BD%E8%A7%A6%E5%8F%91%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%201.%20%E9%80%9A%E8%BF%87%20MSCR%20%E5%AF%84%E5%AD%98%E5%99%A8%E9%85%8D%E7%BD%AE%E7%89%A9%E7%90%86%E5%BC%95%E8%84%9A%20PTD6%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20PTD6%20%E5%AF%B9%E5%BA%94%E4%BA%8E%E7%B4%A2%E5%BC%95%20MSCR%5B102%5D%EF%BC%88%E5%A6%82%E6%82%A8%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMSCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E102%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%B8%85%E9%99%A4%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EMSCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E102%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E19%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IBE%20%3D%201%EF%BC%88%E8%BE%93%E5%85%A5%E7%BC%93%E5%86%B2%E4%BD%BF%E8%83%BD%20-%20%E5%B0%86%E5%BC%95%E8%84%9A%E9%85%8D%E7%BD%AE%E4%B8%BA%E8%BE%93%E5%85%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIMCR%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E542%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E512%3C%2FSPAN%3E%20%3CSPAN%3E)%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E3u%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%8F%AF%E9%80%89%EF%BC%9A%E5%A6%82%E6%9E%9C%E4%BF%A1%E5%8F%B7%E6%98%AF%E6%B5%AE%E5%8A%A8%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%90%AF%E7%94%A8%E4%B8%8A%E6%8B%89%EF%BC%88PUE%3D1%EF%BC%8CPUS%3D1%EF%BC%89%E6%88%96%E4%B8%8B%E6%8B%89%EF%BC%88PUE%3D1%EF%BC%8CPUS%3D0%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%202.%20%E6%BF%80%E6%B4%BB%20EIRQ%5B14%5D%20%E7%BA%BF%E4%B8%8A%E7%9A%84%E8%BE%B9%E7%BC%98%E6%A3%80%E6%B5%8B%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E6%8D%95%E8%8E%B7%E6%AF%8F%E4%B8%AA%E4%B8%8A%E5%8D%87%E6%B2%BF%E7%9A%84%E6%97%B6%E9%97%B4%E6%88%B3%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIREER0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IREER0%5BEIRE14%5D%20%3D%201%20(%E5%90%AF%E7%94%A8%E4%B8%8A%E5%8D%87%E6%B2%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EIFEER0%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3D%3C%2FSPAN%3E%20%3CSPAN%3E~%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20IFEER0%5BEIRE14%5D%20%3D%200%20(%E7%A6%81%E7%94%A8%E4%B8%8B%E9%99%8D%E6%B2%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%203.%20%E8%AF%B7%E6%B1%82%E8%B7%AF%E7%94%B1%EF%BC%9A%E4%BB%8E%E4%B8%AD%E6%96%AD%E6%9B%B4%E6%94%B9%E4%B8%BA%20DMA%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%AD%A4%E6%AD%A5%E9%AA%A4%E7%A1%AE%E4%BF%9D%E8%BE%B9%E6%B2%BF%E4%B8%8D%E4%BC%9A%E5%94%A4%E9%86%92%20CPU%EF%BC%88NVIC%EF%BC%89%EF%BC%8C%E8%80%8C%E6%98%AF%E8%A7%A6%E5%8F%91%20DMA%20%E7%BA%BF%E8%B7%AF%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDIRSR0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20DIRSR0%5BDIRS14%5D%20%3D%201%20(%E9%80%89%E6%8B%A9%20DMA%20%E8%AF%B7%E6%B1%82%E8%80%8C%E4%B8%8D%E6%98%AF%E4%B8%AD%E6%96%AD)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%204.%20%E6%9C%80%E7%BB%88%E5%90%AF%E7%94%A8%20EIRQ%5B14%5D%20%E7%9A%84%20DMA%20%E8%AF%B7%E6%B1%82%E7%94%9F%E6%88%90%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_SIUL2%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EDIRER0%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E1%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E14%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20DIRER0%5BEIRE14%5D%20%3D%201%20(%E6%BF%80%E6%B4%BB%20DMA%20%E8%AF%B7%E6%B1%82%E7%BA%BF)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESetup_DMAMUX_Channel0_ToTCD16_Capture_PIT1%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%201.%20eDMA%20%E9%80%9A%E9%81%93%204%20%E7%9A%84%20DMAMUX%20%E5%88%9D%E5%A7%8B%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20Pod%C4%BEa%20NXP%20tabu%C4%BEky%20prisl%C3%BAcha%20SIUL2%20DMA%20%E8%AF%B7%E6%B1%82%204%20zdrojov%C3%BD%20%E7%B4%A2%E5%BC%95%207u%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_DMAMUX_1-%26gt%3BCHCFG%5B4%5D%20%3D%20DMAMUX_CHCFG_ENBL_MASK%20%7C%20DMAMUX_CHCFG_SOURCE(7u)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E6%8C%89%E7%85%A7%E6%96%87%E6%A1%A3%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%85%88%E7%A6%81%E7%94%A8%E9%80%9A%E9%81%93%204%EF%BC%8C%E7%84%B6%E5%90%8E%E9%85%8D%E7%BD%AE%E5%AE%83%EF%BC%8C%E6%9C%80%E5%90%8E%E5%90%AF%E7%94%A8%E5%AE%83%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_DMAMUX_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHCFG%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0u%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%2F*%202.%20%E9%80%9A%E9%81%93%204%20%E7%9A%84%20TCD%20%E9%85%8D%E7%BD%AE%E6%8C%87%E5%90%91%20PIT_1%EF%BC%88%E5%AE%8C%E5%85%A8%E7%AC%A6%E5%90%88%20S32K3%20%E8%A3%B8%E6%9C%BA%E8%AF%AD%E6%B3%95%EF%BC%89%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%9D%A5%E6%BA%90%EF%BC%9APIT_1%20%E5%AE%9A%E6%97%B6%E5%99%A8%200%20%E7%9A%84%E5%BD%93%E5%89%8D%E5%80%BC%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_SADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EIP_PIT_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETIMER%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D.%3C%2FSPAN%3E%20%3CSPAN%3ECVAL%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_SOFF%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%BA%90%E5%80%BC%E4%B8%8D%E9%80%92%E5%A2%9E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_ATTR%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E0x0202%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%9B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%2032%20%E4%BD%8D%E6%BA%90%EF%BC%8C32%20%E4%BD%8D%E7%9B%AE%E6%A0%87%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E6%AC%A1%E8%A6%81%E5%BE%AA%E7%8E%AF%EF%BC%9A%E6%AF%8F%E6%AC%A1%E8%A7%A6%E5%8F%91%E4%BC%A0%E8%BE%93%E7%9A%84%E5%AD%97%E8%8A%82%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%9C%A8%20S32K3%20%E4%B8%AD%EF%BC%8C%E8%BF%99%E5%AF%B9%E5%BA%94%E4%BA%8E%20NBYTES_MLOFFNO%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88%E6%97%A0%E6%AC%A1%E8%A6%81%E5%BE%AA%E7%8E%AF%E9%93%BE%E6%8E%A5%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ENBYTES16%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_NBYTES_MLOFFNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%AF%8F%E6%AC%A1%E8%A7%A6%E5%8F%91%E4%BC%A0%E8%BE%93%204%20%E5%AD%97%E8%8A%82%EF%BC%8832%20%E4%BD%8D%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E7%9B%AE%E6%A0%87%E4%BD%8D%E7%BD%AE%EF%BC%9A%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E6%95%B0%E7%BB%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_DADDR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3Edma_timestamps%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_DOFF%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F%2F%20%E6%AF%8F%E6%AC%A1%E8%BE%B9%E6%B2%BF%E7%A7%BB%E5%8A%A8%E5%90%8E%EF%BC%8CRAM%20%E4%B8%AD%E7%9A%84%E6%95%B0%E6%8D%AE%E5%B7%A6%E7%A7%BB%204%20%E4%B8%AA%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E5%BE%AA%E7%8E%AF%E7%BC%93%E5%86%B2%E5%8C%BA%EF%BC%9A%E5%A1%AB%E5%85%85%E5%AE%8C%E6%95%B4%E4%B8%AA%E6%95%B0%E7%BB%84%E5%90%8E%E5%BE%AA%E7%8E%AF%E5%9B%9E%E5%88%B0%E6%95%B0%E7%BB%84%E5%BC%80%E5%A4%B4%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_DLAST_SGA%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3E4%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%20%E4%B8%BB%E8%A6%81%E5%BE%AA%E7%8E%AF%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%9A%E5%BE%AA%E7%8E%AF%E4%B8%AD%E7%9A%84%E6%80%BB%E8%BF%AD%E4%BB%A3%E6%AC%A1%E6%95%B0%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_TCD-%26gt%3BCITTER20.TCD20_CITER_ELINKNO%20%3D%20BUFFER_SIZE%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECITER16%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_CITER_ELINKNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EBITER16%3C%2FSPAN%3E%20%3CSPAN%3E.%3C%2FSPAN%3E%20%3CSPAN%3ETCD16_BITER_ELINKNO%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2FIP_TCD-%26gt%3BCH16_CSR%20%7C%3D%203u%3B%20%20%2F%2F%20ERQ%3D1%EF%BC%8CEARQ%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F%2F%E5%90%AF%E7%94%A8DMAMUX%E9%80%9A%E9%81%930%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_DMAMUX_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHCFG%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_ENBL_MASK%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3EDMAMUX_CHCFG_SOURCE%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E6u%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E__asm%3C%2FSPAN%3E%20%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22nop%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E__asm%3C%2FSPAN%3E%20%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22nop%22%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3EIP_TCD%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECH16_CSR%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%3C%2FSPAN%3E%20%3CSPAN%3E3u%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E4%BB%8D%E7%84%B6%E6%97%A0%E6%B3%95%E9%80%9A%E8%BF%87%20EIRQ(14)%20%E5%90%AF%E5%8A%A8%20DMA%20%E4%BC%A0%E8%BE%93%EF%BC%8C%E5%8D%B3%E4%BD%BF%E5%87%BA%E7%8E%B0%E6%AD%A4%E6%96%AD%E8%A8%80%E3%80%82%E5%9C%A8%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%AD%EF%BC%8C%E5%BD%93%E6%88%91%E6%94%B9%E5%8F%98MCU%20PTD6%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9A%84%E4%BF%A1%E5%8F%B7%E6%97%B6%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%A0%87%E5%BF%97%E5%87%BA%E7%8E%B0%E3%80%82%3CBR%20%2F%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%20TCD16_CSR%20START%20%E4%BD%8D%E6%89%8B%E5%8A%A8%E5%90%AF%E5%8A%A8%20DMA%20%E4%BC%A0%E8%BE%93%EF%BC%8CTCD%20%E9%80%9A%E9%81%93%E4%B8%8A%E7%9A%84%20CITTER%20%E5%80%BC%E4%BC%9A%E5%87%8F%E5%B0%8F%EF%BC%8C%E5%B9%B6%E4%B8%94%20PIT1_TIMER%5B0%5D%20%E4%B8%AD%E7%9A%84%E5%80%BC%E4%BC%9A%E8%A2%AB%E5%AD%98%E5%82%A8%E5%88%B0%E6%88%91%E7%9A%84%20dma_timestamps%20%E6%95%B0%E7%BB%84%E4%B8%AD%E3%80%82%3CBR%20%2F%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%9A%E8%BF%99%E5%BA%94%E8%AF%A5%E5%9C%A8%E2%80%9C%E6%99%AE%E9%80%9A%E2%80%9DSRAM%E9%83%A8%E5%88%86%E5%AE%9A%E4%B9%89%E3%80%82%E6%88%91%E4%B9%8B%E5%89%8D%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%95%B0%E6%8D%AE%E7%BC%93%E5%AD%98%E6%AE%B5%EF%BC%8C%E5%AF%BC%E8%87%B4%E5%87%BA%E7%8E%B0%20DMA%E2%80%9C%E7%9B%AE%E6%A0%87%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E2%80%9D%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E6%96%B0%E5%AE%9A%E4%B9%89%EF%BC%9A%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E__attribute__%3C%2FSPAN%3E%20%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3E%E5%AF%B9%E9%BD%90%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E32%3C%2FSPAN%3E%20%3CSPAN%3E)))%3C%2FSPAN%3E%20%3CSPAN%3E__attribute__%3C%2FSPAN%3E%20%3CSPAN%3E((%3C%2FSPAN%3E%3CSPAN%3E%E9%83%A8%E5%88%86%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22.mcal_data%22%3C%2FSPAN%3E%20%3CSPAN%3E)))%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3Edma_timestamps%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3EBUFFER_SIZE%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E8%B7%B3%E8%BF%87%E6%89%8B%E5%8A%A8%20START%EF%BC%88%E4%BB%8E%E4%BB%A3%E7%A0%81%E5%BC%80%E5%A7%8B%E5%B0%B1%E4%B8%8D%E9%9C%80%E8%A6%81%E8%AE%BE%E7%BD%AE%EF%BC%89%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E6%9B%B4%E6%94%B9%20PTD6%20%E5%BC%95%E8%84%9A%E4%B8%8A%E7%9A%84%E4%BF%A1%E5%8F%B7%EF%BC%8CDMA%20%E9%80%9A%E9%81%93%E4%B8%8D%E4%BC%9A%E6%89%A7%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%93%8D%E4%BD%9C%EF%BC%8CCITTER%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%BF%9D%E6%8C%81%E5%9C%A8%E5%88%9D%E5%A7%8B%E5%8C%96%E5%80%BC%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E9%97%AE%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E6%89%BE%E5%87%BA%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E4%BB%8D%E7%84%B6%E8%AE%A4%E4%B8%BA%20PTD6-EIRQ(14)%20%E9%92%B3%E4%BD%8D%E6%A0%87%E5%BF%97%E4%B8%8E%20TCD16%20%E9%80%9A%E9%81%93%E4%B9%8B%E9%97%B4%E7%9A%84%E8%BF%9E%E6%8E%A5%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E5%8F%AF%E8%83%BD%E6%98%AFDMAMUX%E9%80%9A%E9%81%93%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%9D%A5%E6%BA%90%EF%BC%9F%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%20DMAMUX1-CH%5B0%5D%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E6%89%80%E6%9C%89%E4%BF%A1%E5%8F%B7%E6%BA%90%EF%BC%881%20%E5%88%B0%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86DMAMUX%20Excel%E8%A1%A8%E6%A0%BC%E4%B8%AD%E5%88%97%E5%87%BA%E7%9A%84SUIL2%E5%AE%9E%E4%BE%8B%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%88%90%E5%8A%9F%EF%BC%8C%E8%80%8C%E4%B8%94%E6%88%91%E4%B9%9F%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%88%91%E7%9A%84%E6%AD%A5%E9%AA%A4%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2397488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2397488%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E4%BE%9B%E6%82%A8%E5%8F%82%E8%80%83%EF%BC%8C%E4%BD%BF%E7%94%A8%20PTD6%20%E8%A7%A6%E5%8F%91%20DMA%20%E8%BF%9B%E8%A1%8C%E5%8D%95%E6%AC%A1%E6%95%B0%E6%8D%AE%E4%BC%A0%E8%BE%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E5%9F%BA%E4%BA%8E%20S32K344%20%2B%20RTD%207.0.1%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E8%BF%87%E4%BA%86%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%90%91%E4%BD%A0%E4%BF%9D%E8%AF%81%EF%BC%8C%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20PTD6%EF%BC%8C%E6%9D%A5%E6%BA%90%E5%BA%94%E4%B8%BA%207%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EIP_DMAMUX_1%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECHCFG%3C%2FSPAN%3E%20%3CSPAN%3E%5B%3C%2FSPAN%3E%20%3CSPAN%3E0%3C%2FSPAN%3E%20%3CSPAN%3E%5D%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EDMAMUX_CHCFG_ENBL_MASK%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3E%7C%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSPAN%3EDMAMUX_CHCFG_SOURCE%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSTRONG%3E7u%3C%2FSTRONG%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1784689141057.png%22%20style%3D%22width%3A%20668px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392844iEEF9CBF270DF853B%2Fimage-dimensions%2F668x288%3Fv%3Dv2%22%20width%3D%22668%22%20height%3D%22288%22%20role%3D%22button%22%20title%3D%22Senlent_1-1784689141057.png%22%20alt%3D%22Senlent_1-1784689141057.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398120%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20Senlent%EF%BC%8C%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BE%8B%E5%AD%90%E3%80%82%3CBR%20%2F%3E%E7%BB%8F%E8%BF%87%E4%B8%80%E4%BA%9B%E4%BF%AE%E6%94%B9%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E6%9C%89%E4%BA%86%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E7%9A%84%E7%A4%BA%E4%BE%8B%E3%80%82%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%E4%BF%AE%E6%94%B9%E5%90%8E%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%AD%98%E5%9C%A8%E4%B8%80%E4%B8%AA%E9%87%8D%E8%A6%81%E9%97%AE%E9%A2%98%EF%BC%9A%3CBR%20%2F%3E%E5%9C%A8%E6%95%B4%E4%B8%AA%20DMA%20TCD%20%E9%80%9A%E9%81%93%E5%AE%8C%E5%85%A8%E9%85%8D%E7%BD%AE%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%B7%B2%E8%AE%BE%E7%BD%AE%E4%BA%86%E5%90%AF%E7%94%A8%20DMA%20%E8%AF%B7%E6%B1%82%E7%9A%84%20SIUL%20ICU%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CTCD_SADDR%20%E5%92%8C%20TCD_DADDR%20%E4%B8%BA%E7%A9%BA%EF%BC%88%E5%80%BC%E4%B8%BA%E9%9B%B6%EF%BC%89%EF%BC%8C%E4%B9%8B%E5%90%8E%E5%9C%A8%20SUIL%20%E4%B8%AD%E5%90%AF%E7%94%A8%20DMA%20%E8%AF%B7%E6%B1%82%E5%AF%BC%E8%87%B4%20DMA%20%E9%94%99%E8%AF%AF%20-%20%E2%80%9C%E6%BA%90%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%E2%80%9D%EF%BC%8C%E8%BF%99%E8%AE%A9%E6%88%91%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%3CBR%20%2F%3E%E6%9B%B4%E6%94%B9%E5%88%9D%E5%A7%8B%E5%8C%96%E9%A1%BA%E5%BA%8F%E5%90%8E%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%AE%83%E5%BC%80%E5%A7%8B%E5%AF%B9%E6%88%91%E6%9C%89%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E4%BD%86%E6%88%91%E4%BB%8D%E7%84%B6%E4%B8%8D%E5%A4%AA%E7%90%86%E8%A7%A3DMAMUX%E9%80%9A%E9%81%93%E5%92%8CTCD%E9%80%9A%E9%81%93%E4%B9%8B%E9%97%B4%E7%9A%84%E7%A1%AE%E5%88%87%E5%85%B3%E7%B3%BB%E3%80%82%3CBR%20%2F%3E%E6%82%A8%E5%86%99%E9%81%93%EF%BC%8CDMAMUX%20%E5%BA%94%E8%AF%A5%E9%85%8D%E7%BD%AE%E4%B8%BA%20CHCGF%5B0%5D%E3%80%82%3CBR%20%2F%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%20S32k344%20%E5%AE%9A%E5%88%B6%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%90%AF%E5%8A%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%20DMAMUX-CHCFG%5B3%5D%20%E5%B7%B2%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%B9%B6%E4%B8%94%E7%A1%AE%E5%88%87%E5%9C%B0%E8%AF%B4%EF%BC%8C%E5%9C%A8%E5%87%BD%E6%95%B0%3CSPAN%3EDma_Mux_Ip_Init_Privileged%20%E7%9A%84%E4%BB%A3%E7%A0%81%E8%A1%8C%E4%B8%AD%EF%BC%8C%E6%9C%89%3C%2FSPAN%3E%E4%B8%80%E8%A1%8C%E4%BB%A3%E7%A0%81%E5%AF%BC%E8%87%B4%E4%BA%86%E6%AD%A4%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3ERegisterIndex%20%3D%20DMA_MUX_IP_GATE_OFFSET((pConfig-%26gt%3BpChannelConfigArr%5BChannelCount%5D.Channel))%3B%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%BF%99%E6%98%AF%20lauterbach%20Trace32%20%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%85%B6%E4%B8%AD%E7%9C%8B%E5%88%B0%E6%89%80%E6%9C%89%E5%88%9D%E5%A7%8B%E5%8C%96%E6%AD%A5%E9%AA%A4%E4%B9%8B%E5%90%8E%E7%9A%84%E6%9C%80%E7%BB%88%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1784795174339.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393032iCC8A53D23BE55DFF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_0-1784795174339.png%22%20alt%3D%22OndrejK_0-1784795174339.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E5%B0%86%20RTD%20%E6%9B%B4%E6%96%B0%E5%88%B0%207.0.1%20%E7%89%88%E6%9C%AC%E5%90%8E%EF%BC%8C%E6%88%91%E5%9C%A8%20Design%20Studio%20%E4%B8%AD%E9%85%8D%E7%BD%AE%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_1-1784795478141.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393033i872BCBAE32783927%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_1-1784795478141.png%22%20alt%3D%22OndrejK_1-1784795478141.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%A0%B7%E7%90%86%E8%A7%A3%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%E8%BF%99%E9%87%8C%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%203%20%E4%B8%AA%20DMA%20%E5%A4%8D%E7%94%A8%E6%BA%90%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%90%AC%E5%88%B0%E8%BF%99%E4%B8%AA%E6%B6%88%E6%81%AF%E7%9C%9F%E5%A5%BD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E5%88%9A%E5%85%A5%E9%97%A8%E7%9A%84%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E6%9D%A5%E8%AF%B4%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E5%8F%AF%E8%83%BD%E4%BC%9A%E8%AE%A9%E4%BB%96%E4%BB%AC%E6%84%9F%E5%88%B0%E5%9B%B0%E6%83%91%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20S32K348%EF%BC%8C%E6%B2%A1%E6%9C%89%20DMAMUX_3%EF%BC%9B%E5%8F%AA%E6%9C%89%20DMAMUX_0%20%E5%92%8C%20DMAMUX_1%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%3CEM%3E%E2%80%A2%E5%AF%B9%E4%BA%8E%20S32K310%E3%80%81S32K311%20%E5%92%8C%20S32K312%EF%BC%9ADMAMUX_0%20%E9%80%9A%E9%81%93%200%E2%80%935%20%E5%92%8C%20DMAMUX_1%20%E9%80%9A%E9%81%93%200%E2%80%935%20%E5%88%86%E5%88%AB%E6%98%A0%E5%B0%84%E5%88%B0%20eDMA%20%E4%BC%A0%E8%BE%93%E6%8E%A7%E5%88%B6%E6%8F%8F%E8%BF%B0%E7%AC%A6%20(TCD)%200%E2%80%935%20%E5%92%8C%20eDMA%20%E4%BC%A0%E8%BE%93%E6%8E%A7%E5%88%B6%E6%8F%8F%E8%BF%B0%E7%AC%A6%20(TCD)%206%E2%80%9311%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E4%B8%8D%E5%BA%94%E7%BC%96%E7%A8%8B%20DMAMUX_0%20%E9%80%9A%E9%81%93%206-15%20%E5%92%8C%20DMAMUX_1%20%E9%80%9A%E9%81%93%206-15%EF%BC%9B%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%9B%E8%A1%8C%E4%BA%86%E7%BC%96%E7%A8%8B%EF%BC%8C%E4%BB%BB%E4%BD%95%E8%AE%BF%E9%97%AE%E9%83%BD%E5%B0%86%E5%AF%BC%E8%87%B4%E9%80%9A%E9%81%93%208-15%20%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E5%93%8D%E5%BA%94%EF%BC%8C%E6%88%96%E8%80%85%E9%80%9A%E9%81%93%206-7%20%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E5%93%8D%E5%BA%94%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%23FF6600%22%3E%3CEM%3E%E2%80%A2%E5%AF%B9%E4%BA%8E%E5%85%B6%E4%BD%99%E7%9A%84%20S32K3xx%20%E8%AE%BE%E5%A4%87%EF%BC%9ADMAMUX_0%20%E9%80%9A%E9%81%93%200%E2%80%9315%20%E5%92%8C%20DMAMUX_1%20%E9%80%9A%E9%81%93%200%E2%80%9315%20%E5%88%86%E5%88%AB%E6%98%A0%E5%B0%84%E5%88%B0%20eDMA%20%E4%BC%A0%E8%BE%93%E6%8E%A7%E5%88%B6%E6%8F%8F%E8%BF%B0%E7%AC%A6%20(TCD)%200%E2%80%9315%20%E5%92%8C%20eDMA%20%E4%BC%A0%E8%BE%93%E6%8E%A7%E5%88%B6%E6%8F%8F%E8%BF%B0%E7%AC%A6%20(TCD)%2016%E2%80%9331%E3%80%82%3C%2FEM%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BB%A5%E4%B8%8A%E5%86%85%E5%AE%B9%E6%91%98%E8%87%AA%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%EF%BC%8C%E5%BE%88%E5%AE%B9%E6%98%93%E7%90%86%E8%A7%A3%EF%BC%9A%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E2%80%9C%20%3CSTRONG%3EDMA%E7%A1%AC%E4%BB%B6%E9%80%9A%E9%81%93%3C%2FSTRONG%3E%E2%80%9D%E5%AF%B9%E5%BA%94%E4%BA%8ETCD%E7%BC%96%E5%8F%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E6%82%A8%E9%80%89%E6%8B%A9%20DMA_CHANNEL_0%20%E5%88%B0%20DMA_CHANNEL_15%20%E6%97%B6%EF%BC%8C%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20DMAMUX_0%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E5%BD%93%E6%82%A8%E9%80%89%E6%8B%A9%2016%E2%80%9331%20%E6%97%B6%EF%BC%8C%E9%BB%98%E8%AE%A4%E4%BD%BF%E7%94%A8%20DMAMUX_1%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%9C%A8%E6%9C%AC%E4%B8%BB%E9%A2%98%E4%B8%AD%EF%BC%8CPTD6%20%E5%AF%B9%E5%BA%94%E4%BA%8E%20DMAMUX_1%20%E7%9A%84%E6%BA%90%207%EF%BC%8C%E5%9B%A0%E6%AD%A4%E2%80%9CDMA%20%E7%A1%AC%E4%BB%B6%E9%80%9A%E9%81%93%E2%80%9D%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%20DMA_CHANNEL_16%20%E5%88%B0%20DMA_CHANNEL_31%20%E4%B9%8B%E9%97%B4%E7%9A%84%E4%BB%BB%E4%BD%95%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E5%86%8D%E4%B8%BE%E4%B8%80%E4%B8%AA%E4%BE%8B%E5%AD%90%EF%BC%9A%E5%A6%82%E6%9E%9C%E6%82%A8%E9%80%89%E6%8B%A9%20EIRQ%207%20%E6%9D%A5%E8%A7%A6%E5%8F%91%20DMA%EF%BC%8C%E5%88%99%E2%80%9CDMA%20%E7%A1%AC%E4%BB%B6%E9%80%9A%E9%81%93%E2%80%9D%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E4%B8%BA%20DMA_CHANNEL_0%20%E5%88%B0%20DMA_CHANNEL_15%20%E4%B9%8B%E9%97%B4%E7%9A%84%E4%BB%BB%E4%BD%95%E5%80%BC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20SenLent%EF%BC%8C%3CBR%20%2F%3E%20%E5%85%B3%E4%BA%8E%E9%80%89%E6%8B%A9DMA%E9%80%9A%E9%81%93%EF%BC%8C%E6%88%91%E7%9A%84%E6%83%B3%E6%B3%95%E6%98%AF%E5%8F%AF%E4%BB%A5%E4%BB%8E%E7%9B%B8%E5%85%B3%E7%9A%84DMA_MUX%E7%BB%84%E4%B8%AD%E8%87%AA%E7%94%B1%E9%80%89%E6%8B%A9%E4%B8%80%E4%B8%AA%E3%80%82%3CBR%20%2F%3E%20%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E6%B5%8B%E8%AF%95%E4%BA%86%E5%85%B6%E4%BB%96%20DMA_MUX%26lt%3B-%26gt%3B%20%E5%92%8C%20TCD%20%E7%9A%84%E7%BB%84%E5%90%88%EF%BC%8C%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E5%8F%AA%E6%9C%89%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%BB%84%E5%90%88%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%20IP_DMAMUX_1-%26gt%3BCHCFG%5B3%5D%20%E5%92%8C%20TCD16%E3%80%82%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%8E%A5%E4%B8%8B%E6%9D%A5%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E5%85%B6%E4%BB%96%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CP%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B4%5D%20%E5%92%8C%20TCD17%E3%80%82%3CBR%20%2F%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B0%5D%20%E5%92%8C%20TCD16%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E4%B8%BA%E4%BB%80%E4%B9%88%E5%8F%AA%E6%9C%89%20IP_DMAMUX_1-%26gt%3BCHCFG%5B3%5D%20%E5%92%8C%20TCD16%EF%BC%9F%E5%9C%A8%E8%81%8C%E7%9A%84%20%EF%BC%9F%3CBR%20%2F%3EIP_DMAMUX_1-%26gt%3BCHCFG%5Bxx%5D%20%E4%B8%8E%20TCDyy%20%E4%B9%8B%E9%97%B4%E6%98%AF%E4%BB%80%E4%B9%88%E5%85%B3%E7%B3%BB%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2398487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2398487%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%A1%BA%E5%BA%8F%E6%98%AF%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0%26gt%3BCHCFG%5B0%5D%20%E5%92%8C%20TCD0%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B1%5D%20%E5%92%8C%20TCD1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B2%5D%20%E5%92%8C%20TCD2%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B3%5D%20%E5%92%8C%20TCD3%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B4%5D%20%E5%92%8C%20TCD4%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B5%5D%20%E5%92%8C%20TCD5%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B6%5D%20%E5%92%8C%20TCD6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B7%5D%20%E5%92%8C%20TCD7%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B8%5D%20%E5%92%8C%20TCD8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B9%5D%20%E5%92%8C%20TCD9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B10%5D%20%E5%92%8C%20TCD10%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B11%5D%20%E5%92%8C%20TCD11%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B12%5D%20%E5%92%8C%20TCD12%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B13%5D%20%E5%92%8C%20TCD13%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B14%5D%20%E5%92%8C%20TCD14%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_0-%26gt%3BCHCFG%5B15%5D%20%E5%92%8C%20TCD15%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B0%5D%20%E5%92%8C%20TCD16%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B1%5D%20%E5%92%8C%20TCD17%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B2%5D%20%E5%92%8C%20TCD18%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B3%5D%20%E5%92%8C%20TCD19%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B4%5D%20%E5%92%8C%20TCD20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B5%5D%20%E5%92%8C%20TCD21%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B6%5D%20%E5%92%8C%20TCD22%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B7%5D%20%E5%92%8C%20TCD23%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B8%5D%20%E5%92%8C%20TCD24%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B9%5D%20%E5%92%8C%20TCD25%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B10%5D%20%E5%92%8C%20TCD26%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B11%5D%20%E5%92%8C%20TCD27%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B12%5D%20%E5%92%8C%20TCD28%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B13%5D%20%E5%92%8C%20TCD29%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B14%5D%20%E5%92%8C%20TCD30%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EIP_DMAMUX_1-%26gt%3BCHCFG%5B15%5D%20%E5%92%8C%20TCD31%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399097%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20SenLent%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E5%9C%A8%E6%9C%80%E6%96%B0%E7%9A%84%20S32%20DS%20%E9%A1%B9%E7%9B%AE%E4%B8%8A%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%9B%B4%E5%A4%9A%20DMA_MUX%20%E9%85%8D%E7%BD%AE%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%88%AA%E5%9B%BE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785138171795.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393220iE876FDB68AC73DD6%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_0-1785138171795.png%22%20alt%3D%22OndrejK_0-1785138171795.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E5%B0%86%E7%89%88%E6%9C%AC%E4%BB%A3%E7%A0%81%E4%B8%8B%E8%BD%BD%E5%88%B0%E6%88%91%E4%BB%AC%E7%9A%84%E6%9D%BF%E5%90%8E%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_2-1785138306423.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393223iA0E4736A833A17E8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_2-1785138306423.png%22%20alt%3D%22OndrejK_2-1785138306423.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%82%A8%E6%89%80%E8%A7%81%EF%BC%8C%E6%82%A8%E6%89%80%E6%8F%8F%E8%BF%B0%E7%9A%84%20DMA_MUX%20%E5%92%8C%20TCD%20%E7%9A%84%E5%88%86%E9%85%8D%E9%A1%BA%E5%BA%8F%E5%B9%B6%E6%9C%AA%E5%BE%97%E5%88%B0%E9%81%B5%E5%BE%AA%E3%80%82%3CBR%20%2F%3ERTD%E8%BD%AF%E4%BB%B6%E4%B9%9F%E5%AD%98%E5%9C%A8%E5%90%8C%E6%A0%B7%E7%9A%84bug%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399106%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%88%91%E5%8F%AA%E6%98%AF%E8%B0%83%E6%95%B4%E4%BA%86%E6%88%91%E4%B9%8B%E5%89%8D%E9%99%84%E4%B8%8A%E7%9A%84%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%9C%A8%20DMA_MUX_0%20%E4%B8%8A%E5%88%9B%E5%BB%BA%E4%BA%86%202%20%E4%B8%AA%E9%80%9A%E9%81%93%EF%BC%8C%E5%88%86%E5%88%AB%E5%91%BD%E5%90%8D%E4%B8%BA%20DMA_Channel_0%20%E5%92%8C%20DMA_Channel_1%E3%80%82%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%E8%BF%99%E4%BA%9B%E9%80%9A%E9%81%93%EF%BC%8C%E5%88%86%E9%85%8D%E4%BA%86%20DMA_MUX_0-%26gt%3BCHCFG%5B3%5D%20%E5%92%8C%20DMA-MUX_0-CHCFG%5B2%5D%E3%80%82%3CBR%20%2F%3EDMA_MUX_1%20%E4%B8%8A%E4%B9%9F%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E2%80%9C%E6%B7%B7%E5%90%88%E2%80%9D%E9%A1%BA%E5%BA%8F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E6%BC%94%E7%A4%BA%E7%89%88%E6%9C%AC%EF%BC%9B%E6%88%91%E6%B2%A1%E6%9C%89%E5%81%9A%E4%BB%BB%E4%BD%95%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E6%A3%80%E6%B5%8B%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1785142055872.png%22%20style%3D%22width%3A%20713px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393227i366F970E3D183761%2Fimage-dimensions%2F713x383%3Fv%3Dv2%22%20width%3D%22713%22%20height%3D%22383%22%20role%3D%22button%22%20title%3D%22Senlent_0-1785142055872.png%22%20alt%3D%22Senlent_0-1785142055872.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%E9%97%AE%E9%A2%98%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%E3%80%82%E6%82%A8%E8%83%BD%E5%90%A6%E8%A7%A3%E9%87%8A%E5%BE%97%E6%9B%B4%E6%B8%85%E6%A5%9A%E4%B8%80%E4%BA%9B%EF%BC%8C%E6%88%96%E8%80%85%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%E6%B5%8B%E8%AF%95%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E8%83%BD%E5%91%8A%E8%AF%89%E6%82%A8%E6%82%A8%E7%9A%84%E7%96%91%E9%97%AE%E5%87%BA%E5%9C%A8%E5%93%AA%E9%87%8C%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%20target%3D%22_blank%22%3E%40OndrejK%3C%2FA%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%BE%88%E6%98%8E%E6%98%BE%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%B8%8E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E6%88%96%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E7%89%88%E6%9C%AC%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399148%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20Senlent%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E4%B8%8E%E5%8F%A6%E4%B8%80%E4%BD%8D%E5%90%8C%E4%BA%8B%E4%B8%80%E8%B5%B7%E6%B5%8B%E8%AF%95%E4%BA%86%E5%90%8C%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BB%96%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32DS%203.6.3%20%E7%89%88%E6%9C%AC%E3%80%82Ozone%E8%B0%83%E8%AF%95%E5%99%A8%E5%8F%8A%E5%85%B6%E7%BB%93%E6%9E%9C%E4%B8%8E%E4%BD%A0%E7%9A%84%E7%9B%B8%E5%90%8C%E3%80%82%3CBR%20%2F%3E%E7%9C%8B%E6%9D%A5%E4%BD%A0%E6%98%AF%E5%AF%B9%E7%9A%84%E3%80%82%E4%BD%86%E6%88%91%E5%AE%8C%E5%85%A8%E4%B8%8D%E6%B8%85%E6%A5%9A%E6%88%91%3CSPAN%3E%E8%BF%99%E8%BE%B9%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%20%3CLI-EMOJI%20id%3D%22lia_disappointed-face%22%20title%3D%22%3Adisappointed_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399899%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%20SenLent%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E7%BB%88%E4%BA%8E%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E6%89%80%E5%9C%A8%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%E5%9C%A8%E4%BA%8E%20Ozone%20%E5%92%8C%20Lauterbach%20%E5%8F%AA%E6%98%AF%E6%8F%90%E5%87%BA%E4%BA%86%E4%B8%8D%E5%90%8C%E7%9A%84%20DMA_MUX-%26gt%3BCHCFG%20%E6%96%B9%E6%B3%95%EF%BC%8C%E6%9C%80%E7%BB%88%E7%9A%84%E6%8A%80%E5%B7%A7%E6%98%AF%E8%BF%99%E4%BA%9B%20CHCFG%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%9C%A8%20MCU%20%E7%AB%AF%E6%8C%89%E4%BB%A5%E4%B8%8B%E9%A1%BA%E5%BA%8F%E6%98%A0%E5%B0%84%EF%BC%88DMA_MUX_1%20%E7%9A%84%E5%9F%BA%E5%9C%B0%E5%9D%80%E4%B8%BA%200x40284000%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E0x40284000%20-%26gt%3BCHCFG%5B3%5D%3C%2FP%3E%3CP%3E0x40284001%20-%26gt%3BCHCFG%5B2%5D%3C%2FP%3E%3CP%3E0x40284002%20-%26gt%3BCHCFG%5B1%5D%3C%2FP%3E%3CP%3E0x40284003%20-%26gt%3BCHCFG%5B0%5D%3C%2FP%3E%3CP%3E0x40284004%20-%26gt%3BCHCFG%5B7%5D%3C%2FP%3E%3CP%3E0x40284005%20-%26gt%3BCHCFG%5B6%5D%3C%2FP%3E%3CP%3E0x40284006%20-%26gt%3BCHCFG%5B5%5D%3C%2FP%3E%3CP%3E0x40284007%20-%26gt%3BCHCFG%5B4%5D%3C%2FP%3E%3CP%3E0x40284008%20-%26gt%3BCHCFG%5B11%5D%3C%2FP%3E%3CP%3E%E2%80%A6%E2%80%A6%3CBR%20%2F%3E%E8%AF%B7%E7%9C%8B%E6%88%91%E4%B8%8B%E9%9D%A2%E7%9A%84%E6%88%AA%E5%9B%BE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22OndrejK_0-1785316902701.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785316902701.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22OndrejK_0-1785316902701.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F393372iD2C6CF50ED89D482%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22OndrejK_0-1785316902701.png%22%20alt%3D%22OndrejK_0-1785316902701.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BB%8E%E7%8E%B0%E5%9C%A8%E5%BC%80%E5%A7%8B%EF%BC%8C%E6%88%91%E7%9A%84%E7%BB%93%E6%9E%9C%E8%AE%A9%E6%88%91%E6%9C%89%E6%89%80%E6%84%9F%E7%9F%A5%EF%BC%8C%E4%B9%9F%E4%B8%8E%E4%BD%A0%E7%9A%84%E5%BB%BA%E8%AE%AE%E7%9B%B8%E7%AC%A6%E3%80%82%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2399903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348-GPIO%20EIRQ%20to%20DMA%20request%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2399903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CSPAN%3E%3Ca%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253881%22%3E%40OndrejK%3C%2Fa%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%8E%A5%E5%8F%97%E4%B8%BA%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E2%80%9D%E5%85%B3%E9%97%AD%E6%AD%A4%E4%B8%BB%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
