S32K348 ECC set
S32K348 ECC set
1,063件の閲覧回数
youngkin
hello,
I have three questions that need help to answer, thank you!
1. can you provide a ecc  sample
2.  how  can  i  verify the function ?
1,032件の閲覧回数
petervlna
ECC tests are part of the eMCEM driver of SAF / SPD package.
You will find there examples with sophisticated checks for verification.
https://www.nxp.com/design/design-center/software/functional-safety-software/s32-safety-software-fra...
If you prefer your own code / hard coded tests, then refer to the reference manual:
  • Pre‑reqs:
    • RTD clock init configured so ME enables clock to EIM and ERM. If EIM regs don’t respond, it’s almost always a clock gating issue—enable the partition/COFB clock first.
    • Startup code initializes ECC for SRAM (write‑through once) before reads, otherwise first read can trigger multi‑bit errors. (Zephyr & SEGGER notes highlight this as a common pitfall.)
    • Identify an ERM channel that corresponds to the memory master/region you’ll access (e.g., CM7_0 reading SRAM). Channel mapping is in RM; public tutorials summarize the concept.
    High‑level flow:
    1. Enable clocks for EIM & ERM
    2. Configure ERM: enable “single‑bit corrected” interrupt + “multi‑bit error” interrupt for the relevant channel
    3. Set up EIM: choose the SRAM channel, set one data/check bit for injection (single‑bit)
    4. Perform a read of any address in that memory region → ERM should report a correctable error
    5. Clear, then set two bits in EIM (double‑bit)
    6. Read again → expect non‑correctable → your handler should capture/contain the fault
    1. Optionally, scrub (rewrite) the affected location to clear corrected syndromes
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2256591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K348%20ECC%E3%82%BB%E3%83%83%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256591%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E5%9B%9E%E7%AD%94%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8A%A9%E3%81%91%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E8%B3%AA%E5%95%8F%E3%81%8C%203%20%E3%81%A4%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20ECC%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3C%2FP%3E%3CP%3E2.%20CAN%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2256892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K348%20ECC%20set%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2256892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3EECC%20%E3%83%86%E3%82%B9%E3%83%88%E3%81%AF%E3%80%81SAF%2FSPD%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%20eMCEM%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A4%9C%E8%A8%BC%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E6%B4%97%E7%B7%B4%E3%81%95%E3%82%8C%E3%81%9F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%AE%E4%BE%8B%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Ffunctional-safety-software%2Fs32-safety-software-framework-saf-and-safety-peripheral-drivers-spd%3ASAF%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Ffunctional-safety-software%2Fs32-safety-software-framework-saf-and-safety-peripheral-drivers-spd%3ASAF%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%8B%AC%E8%87%AA%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%84%E3%83%8F%E3%83%BC%E3%83%89%E3%82%B3%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%86%E3%82%B9%E3%83%88%E3%82%92%E5%B8%8C%E6%9C%9B%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CUL%3E%0A%3CLI%3E%0A%3CDIV%20style%3D%22font-family%3A%20'Segoe%20UI'%3B%20font-size%3A%2014px%3B%20font-style%3A%20normal%3B%20font-weight%3A%20400%3B%20line-height%3A%2020px%3B%22%3E%0A%3CP%3E%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3ERTD%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%8C%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%20SO%E3%80%81ME%20%E3%81%AF%20EIM%20%E3%81%8A%E3%82%88%E3%81%B3%20ERM%20%E3%81%B8%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82EIM%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8C%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%BB%E3%81%A8%E3%82%93%E3%81%A9%E3%81%AE%E5%A0%B4%E5%90%88%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9A%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%2FCOFB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%89%8D%E3%81%AB%20SRAM%20%E3%81%AE%20ECC%20%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%A9%E3%82%A4%E3%83%88%E3%82%B9%E3%83%AB%E3%83%BC%20%E3%83%AF%E3%83%B3%E3%82%B9)%E3%80%82%E3%81%9D%E3%81%86%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82(Zephyr%20%E3%81%A8%20SEGGER%20%E3%81%AE%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8B%E8%90%BD%E3%81%A8%E3%81%97%E7%A9%B4%E3%81%A8%E3%81%97%E3%81%A6%E5%BC%B7%E8%AA%BF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82)%3C%2FLI%3E%0A%3CLI%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%2F%E9%A0%98%E5%9F%9F%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%20ERM%20%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%AD%98%E5%88%A5%E3%81%97%E3%81%BE%E3%81%99%20(%E4%BE%8B%3A%20SRAM%20%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%20CM7_0)%E3%80%82%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%20%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%AF%20RM%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E5%85%AC%E9%96%8B%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%A7%E6%A6%82%E5%BF%B5%E3%81%8C%E8%A6%81%E7%B4%84%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E5%A4%A7%E3%81%BE%E3%81%8B%E3%81%AA%E6%B5%81%E3%82%8C%3A%3C%2FP%3E%0A%3COL%3E%0A%3CLI%3EEIM%E3%81%A8ERM%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3EERM%E3%81%AE%E8%A8%AD%E5%AE%9A%3A%20%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%80%8C%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%E8%A8%82%E6%AD%A3%E3%80%8D%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%A8%E3%80%8C%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8D%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3EEIM%E3%81%AE%E8%A8%AD%E5%AE%9A%EF%BC%9ASRAM%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E6%B3%A8%E5%85%A5%E7%94%A8%E3%81%AB1%E3%81%A4%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%2F%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%EF%BC%89%3C%2FLI%3E%0A%3CLI%3E%E3%81%9D%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E9%A0%98%E5%9F%9F%E5%86%85%E3%81%AE%E4%BB%BB%E6%84%8F%E3%81%AE%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%20%E2%86%92%20ERM%E3%81%AF%E4%BF%AE%E6%AD%A3%E5%8F%AF%E8%83%BD%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E5%A0%B1%E5%91%8A%E3%81%99%E3%82%8B%3C%2FLI%3E%0A%3CLI%3EEIM%20%E3%81%AE%202%20%E3%81%A4%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%20(%E3%83%80%E3%83%96%E3%83%AB%E3%83%93%E3%83%83%E3%83%88)%3C%2FLI%3E%0A%3CLI%3E%E5%86%8D%E5%BA%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%20%E2%86%92%20%E4%BF%AE%E6%AD%A3%E4%B8%8D%E5%8F%AF%E8%83%BD%E3%81%A8%E4%BA%88%E6%B8%AC%20%E2%86%92%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%E3%81%8C%E9%9A%9C%E5%AE%B3%E3%82%92%E6%8D%95%E6%8D%89%2F%E5%B0%81%E3%81%98%E8%BE%BC%E3%82%81%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3COL%3E%0A%3CLI%3E%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B7%E3%83%B3%E3%83%89%E3%83%AD%E3%83%BC%E3%83%A0%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%BD%B1%E9%9F%BF%E3%82%92%E5%8F%97%E3%81%91%E3%81%9F%E5%A0%B4%E6%89%80%E3%82%92%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%96%EF%BC%88%E6%9B%B8%E3%81%8D%E6%8F%9B%E3%81%88%EF%BC%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3C%2FDIV%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
