S32K344
S32K344
1,404 次查看
Ralphty
Hello:
Hello, may I ask if it is possible to configure corresponding IO ports and operate certain IO ports after S32K344 enters low-power mode? Can you provide some routines in this regard?
Thank you!!!
2 回复数
1,387 次查看
Senlent
Hi@Ralphty
you can not control the port after entering standby mode.
1,380 次查看
Ralphty
Thank you very much for your reply, which helped me clarify my doubts.
Thanks!!!
