S32K344 not generate Port_cfg.h
已解决
跳至解决方案
1,585 次查看
shiqi_seventeen
Hello Team:
When I used EB Tresos generated Port model's code,but It not generated Port_cfg.h code ,I can not find file in my computer disk.And there are something wrong .
So I don't know how to solve it.
1 解答
1,557 次查看
petervlna
In such case.
You either have set post build in Tresos for ADC module.
Or you are missing ADC module at all.
Check some ADC example projects. Usually included in the ADC plugin.
Peter
在原帖中查看解决方案
4 回复数
1,570 次查看
petervlna
Port_CFG.h is part of the PORT module of driver.
Check the driver to see if you have it installed:
Peter
1,561 次查看
shiqi_seventeen
Thanks ffor your reply,Peter:
I confiured setup the driver ,it located in "generate_PC" directory
but I think the "Port_cfg.h" can be generated by EB Tresos .
Because I has been generated it in other Project ,so I can't understand why EB Tresos can't generate it this time.Is there other way to solve it ?
1,558 次查看
petervlna
In such case.
Peter
1,551 次查看
shiqi_seventeen
Thank you Perter
As the before,I carelessly delete  the  generated directory by EB Tresos.So "Port_cfg.h" is also deleted.Last I follow your tips to find it my computer:
Then I think if I click "Generate PC" button,maybe it work.
And it successfully generated in the ouput directory again !
标记 (1)
