S32K344 SWT reset
S32K344 SWT reset
nirmal_masilamani
Contributor V
Hello ,
I am trying to understand the SWT functionality.
I injected stackoverflow to check how SWT reset the controller. Reset happening properly. Reset reason also match with SWT.
when i continously trigger stackoverflow error, After 8 times, controller does not power up.
I check many times, it working exactly 8 times only, is there any specific reason? or is it configurable?
Tags (3)
lukaszadrapa
Hi @nirmal_masilamani
This is caused by reset escalation feature. Take a look at following sections in the reference manual or just search for “reset escalation” keyword in the document for more details:
33.7.7 Functional reset escalation
33.7.8 Destructive reset escalation
It can be disabled by FRET and DRET registers in MC_RGM module.
Lukas
nirmal_masilamani
Contributor V
Hello @lukaszadrapa
Thank you for your response.
I understood that by changing FRET and DRET, we can cfg reset escalation. In Power module there is a parameter for that.
If I keep zero in both, i am able to disable escalation but, if I change the counter between 1 to 15, its not reflecting. Still SWT working only for 8 times.
Tags (3)
%3CLINGO-SUB%20id%3D%22lingo-sub-2383344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20SWT%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20understand%20the%20SWT%20functionality.%3C%2FP%3E%3CP%3EI%20injected%20stackoverflow%20to%20check%20how%20SWT%20reset%20the%20controller.%20Reset%20happening%20properly.%20Reset%20reason%20also%20match%20with%20SWT.%3C%2FP%3E%3CP%3Ewhen%20i%20continously%20trigger%20stackoverflow%20error%2C%20After%208%20times%2C%20controller%20does%20not%20power%20up.%3C%2FP%3E%3CP%3EI%20check%20many%20times%2C%20it%20working%20exactly%208%20times%20only%2C%20is%20there%20any%20specific%20reason%3F%20or%20is%20it%20configurable%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20SWT%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233316%22%20target%3D%22_blank%22%3E%40nirmal_masilamani%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20is%20caused%20by%20reset%20escalation%20feature.%20Take%20a%20look%20at%20following%20sections%20in%20the%20reference%20manual%20or%20just%20search%20for%20%E2%80%9Creset%20escalation%E2%80%9D%20keyword%20in%20the%20document%20for%20more%20details%3A%3C%2FP%3E%0A%3CP%3E33.7.7%20Functional%20reset%20escalation%3C%2FP%3E%0A%3CP%3E33.7.8%20Destructive%20reset%20escalation%3C%2FP%3E%0A%3CP%3EIt%20can%20be%20disabled%20by%20FRET%20and%20DRET%20registers%20in%20MC_RGM%20module.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20SWT%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383860%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20response.%3C%2FP%3E%3CP%3EI%20understood%20that%20by%20changing%20FRET%20and%20DRET%2C%20we%20can%20cfg%20reset%20escalation.%20In%20Power%20module%20there%20is%20a%20parameter%20for%20that.%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20I%20keep%20zero%20in%20both%2C%20i%20am%20able%20to%20disable%20escalation%20but%2C%20if%20I%20change%20the%20counter%20between%201%20to%2015%2C%20its%20not%20reflecting.%20Still%20SWT%20working%20only%20for%208%20times.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nirmal_masilamani_0-1782105382775.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nirmal_masilamani_0-1782105382775.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F389536i541D707DBC689700%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22nirmal_masilamani_0-1782105382775.png%22%20alt%3D%22nirmal_masilamani_0-1782105382775.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
