S32K344 J-FLASH CONNECT
2,177件の閲覧回数
harryoceana
s32k344 uses j-link to download hex file, can not be connected normally, using S32DS debug捕获.PNGging download is normal, how to use j-flash to connect and download hex file normally?
3 返答(返信)
2,131件の閲覧回数
Senlent
Hi@harryoceana
please have a try J-Flash tool
2,153件の閲覧回数
Senlent
Hi@harryoceana
"Attach to CPU failed.Executing connect under reset"
Are you sure you can use S32 DS to debug?
This kind of error indicates that there is a problem with your debug port. Please check the Reset
PIN of J-LINK.
2,147件の閲覧回数
harryoceana
yes,  S32 DS  debug is ok
