S32K344 How to manually trigger one Function Reset
3,291 次查看
KerryJ
IDE is S32DS3.4
RTD is S32K3 RTD AUTOSAR 4.4 VERSION 2.0.0
There is no example program in the IDE, could you help me to get a example about how to manually trigger one Function Reset? thanks!
标记 (1)
2 回复数
3,275 次查看
danielmartynek
Hello @KerryJ,
This is a part of the Power driver API.
Enable the API in the Configuration tool:
Call the Power_Ip_PerformReset() function:
BR, Daniel
3,269 次查看
KerryJ
Thanks you very much.
