Hi @Jason22
HSE-enabled devices do not have the ability to disable HSE_SWT due to security concerns. The internal team performed the self-test from the application core on an SoC with the HSE installed, and no abnormalities were observed.
During the self-test, the HSE is servicing the watchdog, so no reset will be triggered by the HSE. Therefore, the application does not need to disable anything to perform the self-test, as the HSE handles it.
We understand that the documentation may cause confusion, so a ticket has already been raised to verify this situation.
BR, VaneB
