S32K328 – Missing Information: Switching Frequency at PMOS_CTRL (SMPS V15 Regulator)
MarkusÖsterle
I am using the S32K328 with the SMPS option for the V15 regulator.  However, I cannot find any information in the publicly available documentation regarding the switching frequency used at the PMOS_CTRL pin.
Could you provide the switching frequency used by the S32K328 when driving the external PMOS in SMPS mode? This information is required for correct inductor/diode selection.
Thank you.
PavelL
Hello @MarkusÖsterle ,
I’ve summarized the information here so others can follow along.
Operating in DCM with the recommended component values at a 3.3 V supply is not an issue for the device.
Pavel
PavelL
The information about switching frequency is not available.
The S32K3xx - Hardware Design Guidelines, Rev. E2, recommends Schottky diode and 4.7uH - 5.6uH .
The S32K3xx Data Sheet, Rev. 13, specifies 2A Schottky diode and typ. 4.7uH.
Board S32K3x8-Q289 uses PMEG4050EP and 5.6uH, as well as S32K388EVB-Q289. Detailed part number and manufacturer can be found in the BOM file for the board.
Pavel
MarkusÖsterle
Hello @PavelL ,
Thank You, this is the same Information I could find as well.
I was still wondering if it is a Problem for the IC if the inductor is in DCM which would be the case with the recommended values and a 3V3 supply voltage.
Markus
PavelL
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2316426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K328%20%E2%80%93%20Missing%20Information%3A%20Switching%20Frequency%20at%20PMOS_CTRL%20(SMPS%20V15%20Regulator)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316426%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20using%20the%20S32K328%20with%20the%20SMPS%20option%20for%20the%20V15%20regulator.%26nbsp%3B%20However%2C%20I%20cannot%20find%20any%20information%20in%20the%20publicly%20available%20documentation%20regarding%20the%20switching%20frequency%20used%20at%20the%20PMOS_CTRL%20pin.%3C%2FP%3E%3CP%3ECould%20you%20provide%20the%20switching%20frequency%20used%20by%20the%20S32K328%20when%20driving%20the%20external%20PMOS%20in%20SMPS%20mode%3F%20This%20information%20is%20required%20for%20correct%20inductor%2Fdiode%20selection.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20%E2%80%93%20Missing%20Information%3A%20Switching%20Frequency%20at%20PMOS_CTRL%20(SMPS%20V15%20Regulator)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259819%22%20target%3D%22_blank%22%3E%40Markus%C3%96sterle%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EI%E2%80%99ve%20summarized%20the%20information%20here%20so%20others%20can%20follow%20along.%3C%2FP%3E%0A%3CP%3EOperating%20in%20DCM%20with%20the%20recommended%20component%20values%20at%20a%203.3%20V%20supply%20is%20not%20an%20issue%20for%20the%20device.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20%E2%80%93%20Missing%20Information%3A%20Switching%20Frequency%20at%20PMOS_CTRL%20(SMPS%20V15%20Regulator)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316536%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%26nbsp%3B%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThank%20You%2C%20this%20is%20the%20same%20Information%20I%20could%20find%20as%20well.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20was%20still%20wondering%20if%20it%20is%20a%20Problem%20for%20the%20IC%20if%20the%20inductor%20is%20in%20DCM%20which%20would%20be%20the%20case%20with%20the%20recommended%20values%20and%20a%203V3%20supply%20voltage.%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EMarkus%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2316525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K328%20%E2%80%93%20Missing%20Information%3A%20Switching%20Frequency%20at%20PMOS_CTRL%20(SMPS%20V15%20Regulator)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2316525%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259819%22%20target%3D%22_blank%22%3E%40Markus%C3%96sterle%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3EThe%20information%20about%20switching%20frequency%20is%20not%20available.%3C%2FP%3E%0A%3CP%3EThe%26nbsp%3BS32K3xx%20-%20Hardware%20Design%20Guidelines%2C%20Rev.%20E2%2C%20recommends%20Schottky%20diode%20and%26nbsp%3B4.7uH%20-%205.6uH%20.%3C%2FP%3E%0A%3CP%3EThe%20S32K3xx%20Data%20Sheet%2C%20Rev.%2013%2C%20specifies%202A%20Schottky%20diode%20and%20typ.%204.7uH.%3C%2FP%3E%0A%3CP%3EBoard%20S32K3x8-Q289%20uses%20PMEG4050EP%20and%205.6uH%2C%20as%20well%20as%20S32K388EVB-Q289.%20Detailed%20part%20number%20and%20manufacturer%20can%20be%20found%20in%20the%20BOM%20file%20for%20the%20board.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E
