S32K324 DMA initialzation and use
3,313 次查看
DY_Liu
Hi team.
How should I use DMA?
The DMA I configured was debugged normally, but the full speed operation was abnormal.
basic register to configurate.
For example:
1) initialze uart
2) enable uart dma request (key point)
3) config DMAMUX
4) config DMA
5) enable DMA (key point)
标记 (1)
3,253 次查看
DY_Liu
Hi. Julián_AragónM
I found the reason, Cache must be invalidated.
thanks!
4 回复数
3,293 次查看
Julián_AragónM
Hi @DY_Liu
Chapter 14.4 of the S32K3xx MCU Family - Reference Manual provides instructions for initializing the DMA channel MUX.
You can also take a look into this DMA with UART example with the S32K344 in this community post:
I hope you find this helpful!
Julián.
3,280 次查看
DY_Liu
Hi.@Julián_AragónM
Thank you for you help.
But I have a problem, The first call must have a breakpoint, otherwise it will fail.
Type 1:
Type 2:
api:
3,255 次查看
Julián_AragónM
Hi @DY_Liu,
Could you give us more details about the error? What is the problem if the delay is not set? This is so we can reproduce the example to see if the behavior persists.
Julián.
3,254 次查看
DY_Liu
Hi. Julián_AragónM
thanks!
