S32K322 Ethernet Option
klv222
For the S32K322 with Ethernet, is the EMAC enabled or disabled by default? We might end up using a part that has the Ethernet option but would want it fully disabled for our application.
PavelL
Hello @klv222 ,
EMAC is disabled by default. You have to use the module and configure clock for that. So, you may check that clock wasn't defined for that module.
Pavel
