Hello @kjy106906,
In general, input pins should be driven or pulled to either VSS or VDD to avoid leakage current on that pins.
Outputs should not drive any external load.
Not sure what is the state of the pins in the low power mode of your application, I haven't seen the schematic.
BR, Daniel
