S32K312 RTT PRINT Issues
zhaobasui
Hello everyone, I am currently learning how to use the S32K312 chip and configure SWD 1000KHz debugging with JLINK. This way, debugging is normal. However, when trying to use SEGDER's RTT tool to print data, every time I use the upper computer RTT viewer to connect, it will display a successful connection and the chip will run away (regardless of whether it is in Debug mode or not). My chip has a one second cycle Leb light task, and if it is constantly on or off when running, it should not be continuously lowered by RST. JLINK version 8.6.0 also supports S32K312. May I ask why? Thank you
S32K312EVB-Q172
Tags (2)
Julián_AragónM
Hi @zhaobasui,
Have you configured the _SEGGER_RTT variable from the map file to the tool? It is mentioned in this other community post: Solved: How I can use the RTT in S32DS for S32 Platform 3.5 - NXP Community.
Please try contacting SEGGER as well, as this product is not from NXP.
Julián
zhaobasui
The same device, the same upper computer, and the same RTT code can all be printed on S32K144.
%3CLINGO-SUB%20id%3D%22lingo-sub-2171843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20RTT%20PRINT%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20everyone%2C%20I%20am%20currently%20learning%20how%20to%20use%20the%20S32K312%20chip%20and%20configure%20SWD%201000KHz%20debugging%20with%20JLINK.%20This%20way%2C%20debugging%20is%20normal.%20However%2C%20when%20trying%20to%20use%20SEGDER's%20RTT%20tool%20to%20print%20data%2C%20every%20time%20I%20use%20the%20upper%20computer%20RTT%20viewer%20to%20connect%2C%20it%20will%20display%20a%20successful%20connection%20and%20the%20chip%20will%20run%20away%20(regardless%20of%20whether%20it%20is%20in%20Debug%20mode%20or%20not).%20My%20chip%20has%20a%20one%20second%20cycle%20Leb%20light%20task%2C%20and%20if%20it%20is%20constantly%20on%20or%20off%20when%20running%2C%20it%20should%20not%20be%20continuously%20lowered%20by%20RST.%20JLINK%20version%208.6.0%20also%20supports%20S32K312.%20May%20I%20ask%20why%3F%20Thank%20you%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32K312EVB-Q172%2Fpd-p%2FS32K312EVB-Q172%22%20class%3D%22lia-product-mention%22%20data-product%3D%223493-1%22%20target%3D%22_blank%22%3ES32K312EVB-Q172%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20RTT%20PRINT%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254525%22%20target%3D%22_blank%22%3E%40zhaobasui%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EHave%20you%20configured%20the%20_SEGGER_RTT%20variable%20from%20the%20map%20file%20to%20the%20tool%3F%20It%20is%20mentioned%20in%20this%20other%20community%20post%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio%2FHow-I-can-use-the-RTT-in-S32DS-for-S32-Platform-3-5%2Ftd-p%2F1759263%3Flightbox-message-images-1759263%3D250470i09A2DCA6FA681E2B%22%20target%3D%22_blank%22%3ESolved%3A%20How%20I%20can%20use%20the%20RTT%20in%20S32DS%20for%20S32%20Platform%203.5%20-%20NXP%20Community%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EPlease%20try%20contacting%20SEGGER%20as%20well%2C%20as%20this%20product%20is%20not%20from%20NXP.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2171851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K312%20RTT%20PRINT%20Issues%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171851%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20same%20device%2C%20the%20same%20upper%20computer%2C%20and%20the%20same%20RTT%20code%20can%20all%20be%20printed%20on%20S32K144.%3C%2FP%3E%3C%2FLINGO-BODY%3E
