#S32K312 IO input config
joshua9264
I want to used LPUART0 RX,need config IMCR[699],but spec only IMCR[473],So ,what should I do ?
VaneB
Hi @joshua9264
It is noted in Section 10.1.2 of the S32K3xx Reference Manual, Rev. 12, that:
"IMCRs defined in the attached IOMUX file have an offset of 512 with respect to the IMCR number defined in SIUL2 memory map section."
To help clarify how the offset is applied, an example is also provided in Section 4.4.3 of the RM.
BR, VaneB
joshua9264
yes,I found it. thank you
