S32K3 measuring PWM duty cycle (eMIOS ICU IPWM) without blocking
745件の閲覧回数
Hareesh_S
For context -
I am using an eMIOS ICU channel to measure a varying PWM duty cycle in IPWM mode. I am currently able to successfully measure duty cycle in a "blocking" manner.
My input transitions from 100% duty cycle (effectively no PWM) to a PWM signal of a given duty cycle which I need to measure.
My .mex configuration is as follows -
My sample code is as follows -
While this works, I would prefer to start signal measurement once and periodically call Emios_Icu_Ip_GetDutyCycleValues(), without having to call Emios_Icu_Ip_StopSignalMeasurement(), to avoid being blocked before the measurement is complete. Alternatively, if there is a interrupt fired whenever a measurement has completed, that would work for me too.
I have tried only calling Emios_Icu_Ip_StartSignalMeasurement() initially and calling Emios_Icu_Ip_GetDutyCycleValues() periodically (every 1 second, while the PWM frequency is 1kHz), but the data is inaccurate.
From my understanding, SAIC is better suited for varying PWM signals (which I believe fits my usecase), but I assume I could also use IPWM, with a delayed measurement reading. I do not mind if the returned result is slightly delayed or stale by few milliseconds as I am not expecting rapid changes in duty cycle, and the frequency will be constant.
If someone can clarify how I can achieve this using IPWM, or if I can only implement this via SAIC, that would be great.
646件の閲覧回数
petervlna
The issue you’re hitting is a known limitation of the eMIOS ICU IPWM mode on S32K3:
IPWM is inherently “measurement-window based”, not continuous, so reading it periodically without restarting/closing the measurement leads to stale or partially updated values.
IPWM is not designed for unsynchronized periodic polling
You must either:
  • use interrupt notification, or
  • restart measurement before reading, or
  • switch to SAIC for true non-blocking continuous measurement
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2366505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%E3%81%AB%E3%82%88%E3%82%8BPWM%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E6%B8%AC%E5%AE%9A%EF%BC%88eMIOS%20ICU%20IPWM%EF%BC%89%E3%81%AF%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%81%AA%E3%81%97%E3%81%A7%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366505%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%20-%3CBR%20%2F%3E%E7%A7%81%E3%81%AFeMIOS%20ICU%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81IPWM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%A4%89%E5%8C%96%E3%81%99%E3%82%8BPWM%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E7%A7%81%E3%81%AF%E3%80%8C%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E3%80%8D%E6%96%B9%E5%BC%8F%E3%81%A7%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%B8%AC%E5%AE%9A%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB100%25%EF%BC%88%E5%AE%9F%E8%B3%AA%E7%9A%84%E3%81%ABPWM%E3%81%AA%E3%81%97%EF%BC%89%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%8C%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%AE%E3%81%82%E3%82%8B%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AEPWM%E4%BF%A1%E5%8F%B7%E3%81%B8%E3%81%A8%E5%A4%89%E5%8C%96%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE.mex%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Hareesh_S_0-1778951748752.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_0-1778951748752.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_0-1778951748752.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F385658i9281C78FFB88E39D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Hareesh_S_0-1778951748752.png%22%20alt%3D%22Hareesh_S_0-1778951748752.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Hareesh_S_1-1778951764813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_1-1778951764813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_1-1778951764813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F385659i355841AE2F0E388C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Hareesh_S_1-1778951764813.png%22%20alt%3D%22Hareesh_S_1-1778951764813.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Hareesh_S_2-1778952311888.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_2-1778952311888.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Hareesh_S_2-1778952311888.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F385660iB49D07A980A1AC36%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Hareesh_S_2-1778952311888.png%22%20alt%3D%22Hareesh_S_2-1778952311888.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%A7%E3%82%82%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%BF%A1%E5%8F%B7%E6%B8%AC%E5%AE%9A%E3%82%92%E4%B8%80%E5%BA%A6%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%3CSPAN%3E%E6%B8%AC%E5%AE%9A%E5%AE%8C%E4%BA%86%E5%89%8D%E3%81%AB%E5%87%A6%E7%90%86%E3%81%8C%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AE%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Emios_Icu_Ip_StopSignalMeasurement()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%AA%E3%81%8F%E3%80%81%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%20Emios_Icu_Ip_GetDutyCycleValues()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E6%96%B9%E3%81%8C%E6%9C%9B%E3%81%BE%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E6%B8%AC%E5%AE%9A%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E4%BB%95%E7%B5%84%E3%81%BF%E3%81%A7%E3%82%82%E6%A7%8B%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3CSPAN%3E%E6%9C%80%E5%88%9D%E3%81%AB%20Emios_Icu_Ip_StartSignalMeasurement()%20%E3%81%A0%E3%81%91%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%20(PWM%20%E5%91%A8%E6%B3%A2%E6%95%B0%E3%81%8C%201kHz%20%E3%81%AE%E9%96%93%E3%80%811%20%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB)%20Emios_Icu_Ip_GetDutyCycleValues()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E4%B8%8D%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%AF%E3%80%81SAIC%E3%81%AF%E5%8F%AF%E5%A4%89PWM%E4%BF%A1%E5%8F%B7%EF%BC%88%E7%A7%81%E3%81%AE%E7%94%A8%E9%80%94%E3%81%AB%E5%90%88%E8%87%B4%E3%81%99%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E9%81%85%E5%BB%B6%E6%B8%AC%E5%AE%9A%E3%82%92%E4%BC%B4%E3%81%86IPWM%E3%82%82%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%81%AE%E6%80%A5%E6%BF%80%E3%81%AA%E5%A4%89%E5%8C%96%E3%81%AF%E6%83%B3%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%8A%E3%82%89%E3%81%9A%E3%80%81%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%82%E4%B8%80%E5%AE%9A%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%BF%94%E3%81%95%E3%82%8C%E3%82%8B%E7%B5%90%E6%9E%9C%E3%81%8C%E6%95%B0%E3%83%9F%E3%83%AA%E7%A7%92%E7%A8%8B%E5%BA%A6%E9%81%85%E3%82%8C%E3%81%9F%E3%82%8A%E3%80%81%E5%8F%A4%E3%81%8F%E3%81%AA%E3%81%A3%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20IPWM%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%93%E3%82%8C%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%81%E3%81%82%E3%82%8B%E3%81%84%E3%81%AFSAIC%E3%81%A7%E3%81%97%E3%81%8B%E5%AE%9F%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E6%96%B9%E6%B3%95%E3%82%92%E6%98%8E%E7%A2%BA%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8B%E3%81%A8%E5%A4%A7%E5%A4%89%E5%8A%A9%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2366709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20measuring%20PWM%20duty%20cycle%20(eMIOS%20ICU%20IPWM)%20without%20blocking%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81S32K3%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8BeMIOS%20ICU%20IPWM%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AE%E5%88%B6%E9%99%90%E4%BA%8B%E9%A0%85%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20IPWM%E3%81%AF%E6%9C%AC%E8%B3%AA%E7%9A%84%E3%81%AB%E3%80%8C%E6%B8%AC%E5%AE%9A%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%E3%83%99%E3%83%BC%E3%82%B9%E3%80%8D%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E9%80%A3%E7%B6%9A%E7%9A%84%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%B8%AC%E5%AE%9A%E3%82%92%E5%86%8D%E9%96%8B%2F%E7%B5%82%E4%BA%86%E3%81%9B%E3%81%9A%E3%81%AB%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%80%81%E5%8F%A4%E3%81%84%E5%80%A4%E3%82%84%E9%83%A8%E5%88%86%E7%9A%84%E3%81%AB%E3%81%97%E3%81%8B%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%80%A4%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EIPWM%E3%81%AF%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%81%AE%E5%AE%9A%E6%9C%9F%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E5%90%91%E3%81%91%E3%81%AB%E3%81%AF%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E9%80%9A%E7%9F%A5%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%3C%2FLI%3E%0A%3CLI%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E5%89%8D%E3%81%AB%E6%B8%AC%E5%AE%9A%E3%82%92%E5%86%8D%E9%96%8B%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%3C%2FLI%3E%0A%3CLI%3E%E7%9C%9F%E3%81%AE%E3%83%8E%E3%83%B3%E3%83%96%E3%83%AD%E3%83%83%E3%82%AD%E3%83%B3%E3%82%B0%E9%80%A3%E7%B6%9A%E6%B8%AC%E5%AE%9A%E3%81%AB%E3%81%AFSAIC%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%94%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
