S32K3: RTD5 SAF_EVAL compatibility
myst
I am validating the SAF functionalities using SAF_EVAL. However, the team adopted RTD5, and it seems that S32K3_SAF_1.0.4_EVAL_DS is not compatible with RTD5. As a result, I cannot select an MCU.
Is there anything I can do to solve this problem besides reverting to RTD4
petervlna
Please respect the release notes for SAF 1.0.4 EVAL.
You cannot do anything on your side with this issue.
There is most probably planned release of the SAF for RTD 5.0 but I have no closer information here and even if I have I am not able to share such on public community.
best regards,
Peter
myst
Ok! Thanks!
