S32K3 RTD Power reset api box does not change Power_Ip_Cfg_Defines value
pb632146
Contributor V
I was trying to figure out why ticking the box did not enable the  Power_Ip_PerformReset() API and it seems that the define does not change. Why is this happening? Manually changing the define seems to work but it is a little annoying
ChowZJ
HI, @pb632146
Have you found the cause? I am experiencing the same problem.
Senlent
Hi@pb632146
For example, you can click "change" to see the code is changed or not
pb632146
Contributor V
Yeah even in the update code section it shows that it doesnt change anything
I suppose this is more of a bug report than anything that the peripherals tab isn't translating properly to the code changes.
Senlent
Hi@pb632146
Could you please tell me the IDE and RTD version you're using, i will try to reproduce this problem and give you feedback from myside.
pb632146
Contributor V
ide 3.6 and rtd 5.0
Senlent
Hi@pb632146
You can see there is no such problem on myside.
