S32K3 JTAG Password Protection
2,298件の閲覧回数
ASN7
MCU: S32K314
RTD: 3.0
HSE_B : For S32K3X4 - v0.2.1.0
I am try to password protect my JTAG on the board using HSE(I am not using Challenge/Response).
These are the steps that I am following:
1. Read the HSE Version to make sure it is active.
SOC Type ID= 5, Major Version= 2, Minor Version=1
HSE Response = 0x55a5aa33 = Success
2. Read the current lifecycle.
Current LC = 0x4 = HSE_LC_CUST_DEL
3. Check if HSE_APP_DEBUG_KEY_ATTR_ID is already set.
I do not get HSE_SRV_RSP_NOT_ALLOWED, which means ADKP is set.
4. If not set, then Set up the ADKP.
5. Check if debug auth mode set to password mode
I see 0x00 which is HSE_DEBUG_AUTH_MODE_PW.
6. I advance the Lifecycle.
    hseAttrSecureLifecycle_t programLC = HSE_LC_SIMULATED_OEM_PROD;
    HSE_AdvanceLifecycle(programLC);
In this step, I get this error: 0xAA55A21CUL = HSE_SRV_RSP_NOT_ALLOWED = The operation is not allowed because of some restrictions (in attributes, life-cycle dependent operations, key-management, etc.) */
And the program is now stuck in  ASSERT(HSE_SRV_RSP_OK == srvResponse);.
What is it that is causing the issue ? I tried to change the lifecycle to HSE_LC_IN_FIELD, HSE_LC_OEM_PROD and even HSE_LC_SIMULATED_OEM_PROD (which is what I want). But all of them throw the same error. I have set everything that is needed.
タグ(4)
4 返答(返信)
2,265件の閲覧回数
davidtosenovjan
This procedure seems to be right. Question is how it is actually done.
Which example code are you based on?
2,258件の閲覧回数
ASN7
I created a new project just to test locking of JTAG and all my reference have been from S32K344_DemoAppTemplate.
I have copied the files and functions from S32K344_DemoAppTemplate\services\src\fw_attribute\otp\hse_debug_auth_mode.c.
2,234件の閲覧回数
davidtosenovjan
Don't you have set CUST_START_AS_USER what would lead in having User rights after reset?
1,060件の閲覧回数
kerti1
Thanks for the reply. If user rights set CUST_START_AS_USER then it won't be able to change the LC and also cannot format the keycatalogs. Even If the LC is changed to SIMULATED_OEM using super user rights. The JTAG is not getting locked
%3CLINGO-SUB%20id%3D%22lingo-sub-2130009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20JTAG%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E4%BF%9D%E8%AD%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EMCU%3A%20S32K314%3C%2FDIV%3E%3CDIV%3ERTD%3A%203.0%3C%2FDIV%3E%3CDIV%3EHSE_B%20%3A%20S32K3X4%E7%94%A8%20-%20v0.2.1.0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EHSE%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AEJTAG%E3%82%92%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%81%A7%E4%BF%9D%E8%AD%B7%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%88%E3%83%81%E3%83%A3%E3%83%AC%E3%83%B3%E3%82%B8%2F%E3%83%AC%E3%82%B9%E3%83%9D%E3%83%B3%E3%82%B9%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E7%A7%81%E3%81%8C%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1.%20HSE%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESOC%E3%82%BF%E3%82%A4%E3%83%97ID%3D5%E3%80%81%E3%83%A1%E3%82%B8%E3%83%A3%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D2%E3%80%81%E3%83%9E%E3%82%A4%E3%83%8A%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%E5%BF%9C%E7%AD%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E2.%20%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%81%AELC%20%3D%200x4%20%3D%20HSE_LC_CUST_DEL%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%E5%BF%9C%E7%AD%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E3.%20HSE_APP_DEBUG_KEY_ATTR_ID%20%E3%81%8C%E6%97%A2%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE_SRV_RSP_NOT_ALLOWED%20%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81ADKP%20%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%E5%BF%9C%E7%AD%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E4.%20%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81ADKP%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E5.%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%AA%8D%E8%A8%BC%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E0x00%20%E3%81%AF%20HSE_DEBUG_AUTH_MODE_PW%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E6.%E7%A7%81%E3%81%AF%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92%E6%8E%A8%E9%80%B2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EhseAttrSecureLifecycle_t%20programLC%20%3D%20HSE_LC_SIMULATED_OEM_PROD%3B%3C%2FDIV%3E%3CDIV%3EHSE_AdvanceLifecycle(programLC)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%A7%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%200xAA55A21CUL%20%3D%20HSE_SRV_RSP_NOT_ALLOWED%20%3D%20%E5%B1%9E%E6%80%A7%E3%80%81%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E4%BE%9D%E5%AD%98%E6%93%8D%E4%BD%9C%E3%80%81%E3%82%AD%E3%83%BC%E3%83%9E%E3%83%8D%E3%82%B8%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AA%E3%81%A9%E3%81%AE%E5%88%B6%E9%99%90%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%93%8D%E4%BD%9C%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E7%8F%BE%E5%9C%A8%E3%80%81ASSERT(HSE_SRV_RSP_OK%20%3D%3D%20srvResponse)%3B%20%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%83%A9%E3%82%A4%E3%83%95%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%E3%82%92HSE_LC_IN_FIELD%E3%80%81HSE_LC_OEM_PROD%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E3%81%AFHSE_LC_SIMULATED_OEM_PROD%EF%BC%88%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E5%B8%8C%E6%9C%9B%E3%81%A7%E3%81%99%EF%BC%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E5%85%A8%E3%81%A6%E3%81%A7%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%E3%81%AF%E5%85%A8%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%81%8CCUST_START_AS_USER%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81LC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%80%81%E3%82%AD%E3%83%BC%E3%82%AB%E3%82%BF%E3%83%AD%E3%82%B0%E3%82%92%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6LC%E3%82%92SIMULATED_OEM%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%A7%E3%82%82%E3%80%82JTAG%E3%81%8C%E3%83%AD%E3%83%83%E3%82%AF%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2132537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E6%A8%A9%E9%99%90%E3%81%8C%E4%BB%98%E4%B8%8E%E3%81%95%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%A8%E3%81%AA%E3%82%8BCUST_START_AS_USER%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2131657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJTAG%E3%81%AE%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8F%82%E7%85%A7%E3%81%97%E3%81%9F%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AFS32K344_DemoAppTemplate%E3%81%8B%E3%82%89%E3%81%AE%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20S32K344_DemoAppTemplate%5Cservices%5Csrc%5Cfw_attribute%5Cotp%5Chse_debug_auth_mode.c%20%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E9%96%A2%E6%95%B0%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2131502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%82%88%E3%81%86%E3%81%A0%E3%80%82%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22HwtZe%22%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E3%81%A9%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
