S32K148EVB PCB layout files
1,537 次查看
Poley
Contributor V
Is it possible to get PCB design files that can be opened in Altium? Looking to make a PCB similar to the dev board design so this would be very useful. I have signed the NDA for docstore.
Thank you!
5 回复数
1,525 次查看
petervlna
I will check it internally, but as far as I know we use Cadance.
Peter
1,523 次查看
Poley
Contributor V
Hi @petervlna
I think Cadance files can still be imported to Altium? Not 100% sure on that though. Would appreciate the files to see if I can import it.
Thanks for the help!
1,510 次查看
petervlna
I have asked for layout files, but you will need to submit a ticket and possibly sign NDA (I will check this).
Pleas create ticket:
https://community.nxp.com/t5/HomeTest-Knowledge-Base/How-to-submit-a-new-question-for-NXP-Support/ta...
best regards,
Peter
1,500 次查看
petervlna
I have the layout files now. I am waiting for the ticket from you as I cannot share them via community.
Peter
1,497 次查看
Poley
Contributor V
Hi @petervlna
I have opened a support case #00373169.
thank you very much!
