S32K148
S32K148
1396617186
I would like to inquire whether the S32K148 microcontroller, FTM3-CH0, FTM3-CH1,FTM3-CH2,FTM3-CH3,FTM3-CH4 and FTM3-CH1 can only output PWM of the same frequency?
Julián_AragónM
Hi @1396617186,
It's not possible to generate different PWM frequencies under the same module base.
Although, each pair of channels can be combined to generate a PWM signal with independent control of both edges of PWM signal.
This document may prove useful: AN5303: Features and Operation Modes of FlexTimer Module on S32K.
Julián.
