S32K148 problem with reception in ENET module
victor_mt
Hello everyone,
I am running the S32K148 using ENET module with DMA. The issue is that it stops receiving ethernet messages after operating for a while (30-40 min). What I have seen is that field E in uDMA receive buffer descriptor does not change anymore
We have many S32K148 devices in our network, as well as some Acksys switches. It appears that this behavior occurs, as I said, after some time operating, when it receives a message that Acksys devices send each other. This occurs to every S32K148 in the network.
Any ideas on where to look to solve this?
Victor
PetrS
can you specify a driver versions (SDK, RTD, Stacks) you are using?
Does this hang condition happen under some heavy load conditions or similar? What are messages switches exchange? Is a ENET detecting any kind of error? Maybe ENET statistic counters can be used with finding root cause.
Below are some threads dealing with receive hanging
https://community.nxp.com/t5/S32K/Lwip-stack-gets-hanged-in-netconn-recv-api/td-p/1678495/page/2
https://community.nxp.com/t5/S32K/S32K148-ENET-Rx-stuck-after-heavy-traffic/m-p/905607
BR, Petr
