S32K148 QSPI
S32K148 QSPI
1,663 次查看
peter_scheunert
is it possible to use the external QSPI flash as program memory? If yes, how is the execution speed compared to internal memory?
1 回复
1,616 次查看
davidtosenovjan
Hi, yes it can. It even exist example code showing that:
https://www.nxp.com/docs/en/application-note/AN12193.pdf
However the device cannot boot from QuadSPI memory.
