Hi@ShaoTianzhi
please check the register CS->DBG is set or not.
If this bit is configured to 1, in debugging mode, after encountering the breakpoint set by the user and stopping, the WDOG watchdog counter will still count, so that it will overflow and trigger the MCU reset soon.
please refer the demo wdog_interrupt_s32k146 which provided by S32 DS.
don't enable debug mode then try again.
