S32K144EVB-Q100 Factory Firmware and Code
ソリューションへジャンプ
4,686件の閲覧回数
tpcom
Who can provide the download address for S32K144EVB-Q100 Factory Firmware and Code.
Thinks!
4,669件の閲覧回数
Robin_Shen
Hi tpcom,
Do you mean the FreeMASTER JumpStart project mentioned in Get Started? If so, please refer to Q&A of S32K1x FreeMASTER JumpStart Project
Robin
4 返答(返信)
4,670件の閲覧回数
Robin_Shen
Hi tpcom,
Robin
4,658件の閲覧回数
tpcom
Thank you very much Robin. I have found this program. In addition, there are independent programs for each peripheral device on this file “Document Number: AN5413 Rev. 0, 03/2017”. It is Application Note of NXP Semiconductors. Where can I download every code for the "Hello World ... CAN FD"?
4,648件の閲覧回数
Robin_Shen
Search AN5413, you will find the AN5413SW
タグ(1)
4,639件の閲覧回数
tpcom
The problem has been solved. Thank you very much for your support.
