S32K144 flash simulation EEPROM
zhengwei_tao
Hello!
I have encountered a problem when I use the flash to simulate the EEPROM. Is the maximum available space of the EEPROM used by the EEPROM simulated by flexram 64 kB+flexnvm 4kB = 68 KB?
Also, when the data I write is saved to the eeprom backup area, how do I access the data, I tried to use the pointer to directly access the dflash base, but an error will be reported, please help answer, thank you.
Senlent
