S32K144 Pin-Outs
S32K144 Pin-Outs
12,784件の閲覧回数
andyfraser
I am hoping to use the S32K144 64-pin device in the near future and thought I would create a schematic symbol for it. However, I am having difficulty locating the pin-out diagram. In the S32K1XX datasheet it says "For package pinouts and signal descriptions, refer to the Reference Manual." and in the Reference Manual is says "See IO Signal Description Input Multiplexing sheet(s) attached to the Reference Manual for pinout diagrams corresponding to available packages.".
So, where are the pin-outs ?!
Andy
3 返答(返信)
8,591件の閲覧回数
isaaclee
Is there any reason why you put the document as an attachment instead of putting it in the same document?
It seems a bit inconvenient for the viewer only.
10,249件の閲覧回数
andyfraser
Daniel,
Many thanks - I did not realize that you can attach files to a PDF !
Thanks again.
Andy
10,249件の閲覧回数
danielmartynek
You can find the latest RM Rev3 on the product page.
The pin out is then in the attachments:
