S32K144 FlexRAM (EEPROM)partition
emb02
Contributor V
I'm using S32K144 controller and I want to use FlexRAM memory for EEPROM storage.
I'm using 3 sections - Primary bootloader, secondary bootloader and firmware, so I want to partition FlexRAM memory for these 3 sections.
Eg.
In S32K144 Total 4KB memory is available for FlexRAM.
For primary bootloader - 512 Bytes
For Secondary bootloader - 512 Bytes
For Firmware - 3 KBytes
I'm using 3 projects for this configuration so I'm not getting how to configure FlexRAM in each project.
Is there any reference code available for this?
Tags (3)
Senlent
Hi@emb02
First, the partitioning operation cannot divide the FlexRAM into multiple independent areas. In other words, you cannot perform three different partition operations on the MCU for three different projects; you can only perform a partition operation once. The partitioning operation will erase the contents of the E-Flash.
You can partition all 64KB of FlexNVM as E-Flash, allowing different projects to access FlexRAM.
Demo code:
1.you can find demo in S32 DS
2.AN11983
