S32K144 FlexCAN Error
2,616件の閲覧回数
raviranjankumar
   I am working on S32K144 EVB. Intentionally I am creating an  error to check error handling. Only one time I am sending data. If I not connected to CAN bus, I am getting ACKERR, BIT0ERR, BIT1ERR. After hitting error handler
I am clearing all these errors . After clearing error also repeatedly hitting the handler.
Please help.
Thanks and Regards,
Ravi Ranjan.
2 返答(返信)
2,227件の閲覧回数
jinshuaixu
Contributor V
I think you should upload you project.
2,227件の閲覧回数
raviranjankumar
Hi Jinshuai xu,
   Thanks for reply. Actually that issue is solved. I was not clearing Overrun Error bit. After clearing that, it is not hitting handler repeatedly.
Thanks and Regards,
Ravi Ranjan.
