S32K144 Flash Driver C90TFS - Selection
najongmin
I installed Standard Software Driver v1.0.4 (C90TFS) for S32K144 Flash driving.
I want to import the c-array flash driver to my application.
But there is 3 types of driver.. What should i use as S32K144 Flash driver?
Plus, Let me know the flash blocks configuration of K144's 512KB Flash memory.
(For example, 64KB x 2EA, 128KB x 1EA.... so on)
Omar_Anguiano
I suggest you use the flash driver from the SDK of S32K11. If you are using S32DS the latest version is included in the IDE. You can find the SDK here: https://www.nxp.com/design/software/development-software/s32-sdk/s32-software-development-kit-for-s3...
You can find the device memory map attached in the S32K reference manual.
Let me know if this is helpful, if you have more questions do not hesitate to ask me.
Omar
