S32K144 Cortex-M4 Control register
Loky
Control register bit0:nPRIV only define the Thread mode privilege level, in handler mode, software execution is always privileged. so when in handler mode, what register should be observed to determine if the current state must be in privileged mode?
an embedded software engineer
petervlna
In Handler mode, privilege is always enabled.
To detect Handler mode, check IPSR ≠ 0.
In Thread mode, check CONTROL.nPRIV to determine privilege.
Peter
petervlna
Peter
%3CLINGO-SUB%20id%3D%22lingo-sub-2156389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K144%20Cortex-M4%20Control%20register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EControl%20register%20bit0%3AnPRIV%20only%20define%20the%20Thread%20mode%20privilege%20level%2C%20in%20handler%20mode%2C%20software%20execution%20is%20always%20privileged.%20so%20when%20in%20handler%20mode%2C%20what%20register%20should%20be%20observed%20to%20determine%20if%20the%20current%20state%20must%20be%20in%20privileged%20mode%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K144%20Cortex-M4%20Control%20register%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156501%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EIn%26nbsp%3BHandler%20mode%2C%20privilege%20is%26nbsp%3Balways%20enabled.%3C%2FP%3E%0A%3CP%3ETo%20detect%20Handler%20mode%2C%20check%26nbsp%3BIPSR%20%E2%89%A0%200.%3C%2FP%3E%0A%3CP%3EIn%26nbsp%3BThread%20mode%2C%20check%26nbsp%3BCONTROL.nPRIV%26nbsp%3Bto%20determine%20privilege.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EPeter%3C%2FP%3E%3C%2FLINGO-BODY%3E
