S32K144_64pin cannot init.
1,860件の閲覧回数
lpblueice
Hi all,
I am debugging on my S32K144_64pin board.
I have tried in the EVB 100pin board with the demo provided by NXP.
Then I use the same demo project in the S32K144_64pin board after changing 100pin to 64pin in the project.
However, the project stuck in the PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr) and "b       DefaultISR" in startup_S32K144.S .
I have found the same issue in the following path:
64 pins' S32K144 use PE enter Default
Could you please help me to resolve this problem? Thank you!
1,701件の閲覧回数
jxl
Hi Peter,
   Have u solved this problem? I also have this problem when I use 64-pin S32K142.
