S32K142 bootloader default ISR
kentseng
Dear all
I modify the project from S32K144 to S32K142, but bootloader IRQ happened.
could you help me fix the issue ?
Tags (3)
dianabatrlova
Could you, please, be more specific, for example, to share the code where the Default ISR occurs?
Or can you share your project?
Also, please, check whether you have enabled clock source for peripherals.
Thank you.
Diana
