S32K142 Flexio_SPI continus cs problem
jayeechou
Hallo,
   I use flexio for spi commumication in S32K142 MCU. My slave chip needs a countinus cs signal for exchange datas. However I find flexio_spi will send one byte with one cs signal. Next byte will be with a new and independent cs signal. My problem is how to set a continus cs signal in flexio_spi? This is Joey waiting for your support. Thanks!
Tags (2)
jayeechou
OK. I find the solution that CS pin is configed as GPIO instead of the FlexIO. Then I can manually control it.
