S32K118Q048 LIN Stack
已解决
跳至解决方案
1,586 次查看
yousefdessouki123
I’m working with the LIN stack on an NXP S32K118Q048 EVB to set up a LIN network using an .ldf file. When I upload the .ldf for parsing, I encounter terminal errors stating that some frames are missing from the configurable_frames section in the Node_attributes.
Upon investigation, I found that the missing frames are unconditional frames mapped under a sporadic frame. Interestingly, the error disappears if I explicitly add the sporadic frame name to the configurable_frames list — which seems odd, since sporadic frame names are typically referenced in the schedule table, not in the node configuration. I have doubled checked the LIN 2.0 protocol revision and could not find an explanation for this error that could help me.
For context, I'm using the LIN 2.0 protocol.
1 解答
2 回复数
1,565 次查看
danielmartynek
Hi @yousefdessouki123,
Which S32DS IDE version, RTD version and LIN Stack version do you use?
Thank you
1,547 次查看
danielmartynek
%3CLINGO-SUB%20id%3D%22lingo-sub-2138297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K118Q048%20LIN%20%E5%A0%86%E6%A0%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20S32K118Q048%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%20LIN%20%E5%A0%86%E6%A0%88%EF%BC%8C%E4%BD%BF%E7%94%A8%20.ldf%20%E8%AE%BE%E7%BD%AE%20LIN%20%E7%BD%91%E7%BB%9C%E9%94%89%E5%88%80%E5%BD%93%E6%88%91%E4%B8%8A%E4%BC%A0%20.ldf%E8%A7%A3%E6%9E%90%E6%97%B6%EF%BC%8C%E4%BC%9A%E9%81%87%E5%88%B0%E7%BB%88%E7%AB%AF%E9%94%99%E8%AF%AF%EF%BC%8C%E6%8F%90%E7%A4%BA%20Node_attributes%20%E4%B8%AD%E7%9A%84%20configurable_frames%20%E9%83%A8%E5%88%86%E7%BC%BA%E5%B0%91%E6%9F%90%E4%BA%9B%E5%B8%A7%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E7%BB%8F%E8%BF%87%E8%B0%83%E6%9F%A5%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E4%B8%A2%E5%A4%B1%E7%9A%84%E5%B8%A7%E6%98%AF%E9%9B%B6%E6%98%9F%E5%B8%A7%E4%B8%8B%E6%98%A0%E5%B0%84%E7%9A%84%E6%97%A0%E6%9D%A1%E4%BB%B6%E5%B8%A7%E3%80%82%E6%9C%89%E8%B6%A3%E7%9A%84%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E6%98%8E%E7%A1%AE%E5%9C%B0%E5%B0%86%E9%9B%B6%E6%98%9F%E5%B8%A7%E5%90%8D%E7%A7%B0%E6%B7%BB%E5%8A%A0%E5%88%B0configurable_frames%E5%88%97%E8%A1%A8%E4%B8%AD%EF%BC%8C%E9%94%99%E8%AF%AF%E5%B0%B1%E4%BC%9A%E6%B6%88%E5%A4%B1%E2%80%94%E2%80%94%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E5%A5%87%E6%80%AA%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%9B%B6%E6%98%9F%E7%9A%84%E5%B8%A7%E5%90%8D%E7%A7%B0%E9%80%9A%E5%B8%B8%E5%9C%A8%E8%AE%A1%E5%88%92%E8%A1%A8%E4%B8%AD%E5%8F%82%E8%80%83%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%E8%8A%82%E7%82%B9%E9%85%8D%E7%BD%AE%E4%B8%AD%E5%8F%82%E8%80%83%E3%80%82%E6%88%91%E4%BB%94%E7%BB%86%E6%A3%80%E6%9F%A5%E4%BA%86%20LIN%202.0%20%E5%8D%8F%E8%AE%AE%E7%9A%84%E4%BF%AE%E8%AE%A2%E7%89%88%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E5%AF%B9%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E7%9A%84%E8%A7%A3%E9%87%8A%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E4%B8%BA%E4%BE%BF%E4%BA%8E%E7%90%86%E8%A7%A3%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20LIN%202.0%20%E5%8D%8F%E8%AE%AE%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118Q048%20LIN%20Stack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251159%22%20target%3D%22_blank%22%3E%40yousefdessouki123%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20S32DS%20IDE%E3%80%81RTD%20%E5%92%8C%20LIN%20%E5%A0%86%E6%A0%88%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
