S32K118 Watchdog Issue
已解决
跳至解决方案
2,354 次查看
bjs
I have a demo project developed on s32k118evb board with watchdog disabled and it works well but after I download the project to my prototype PCB board the program triggers a watchdog timeout.
Is there anything I missed to disable the watchdog timer?
====== Below is the board initialization code ======
/* Board Initialization */
void Board_Init()
#if 1
DISABLE_INTERRUPTS(); // disable global interrupt
WDOG->CNT=0xD928C520;     /* Unlock watchdog */
WDOG->TOVAL=0x0000FFFF;    /* Maximum timeout value */
WDOG->CS = 0x00002100;    /* Disable watchdog */
ENABLE_INTERRUPTS(); // enable global interrupt
#endif
/* Clock */
CLOCK_DRV_Init(&clockMan1_InitConfig0);
PINS_DRV_Init(NUM_OF_CONFIGURED_PINS, g_pin_mux_InitConfigArr);
/*** SPI ***/
LPSPI_DRV_MasterInit(MLX,&mlxState,&mlx_MasterConfig0);
/*** LPIT ***/
LPIT_DRV_Init(INST_LPIT1, &lpit1_InitConfig);
LPIT_DRV_InitChannel(INST_LPIT1, CHAN_0, &lpit1_ChnConfig0);
INT_SYS_InstallHandler(LPIT0_IRQn, &LPIT_ISR, (isr_t *)0);
LPIT_DRV_StartTimerChannels(INST_LPIT1, CHAN_0_MASK);
/*** CAN ***/
/* Initialize can pal instance */
/* !!! PE clock source MUST be peripheral clock !!! */
CAN_Init(&hscan_instance, &hscan_Config0);
/* Set buffer configuration */
CAN_ConfigTxBuff(&hscan_instance, TX_MAILBOX, &TxbuffCfg);
msg.id = HSCAN_ID;
msg.cs = 0U;
msg.length = 8;
/*** SBC Control ***/
// Set SBC control pin to enter normal mode
PINS_DRV_SetPins(STBN_PORT, STBN_PIN);
1 解答
2,322 次查看
Robin_Shen
If you are using the S32K1 SDK examples, there is DISABLE_WDOG in system_S32K118.c and system_S32K118.h that can be used to disable the watchdog:
/SDK/platform/devices/S32K118/startup/system_S32K118.c
But I don't understand why it runs normally on S32K118EVB but errors occur on your prototype PCB board. Have you compared the differences between crystal circuits?
Robin
在原帖中查看解决方案
1 回复
2,323 次查看
Robin_Shen
Robin
%3CLINGO-SUB%20id%3D%22lingo-sub-1874771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K118%E7%9C%8B%E9%97%A8%E7%8B%97%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%9C%A8%20s32k118evb%20%E6%9D%BF%E4%B8%8A%E5%BC%80%E5%8F%91%E7%9A%84%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%85%B6%E4%B8%AD%E7%9C%8B%E9%97%A8%E7%8B%97%E8%A2%AB%E7%A6%81%E7%94%A8%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%AE%83%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E4%BD%86%E6%98%AF%E5%9C%A8%E6%88%91%E5%B0%86%E9%A1%B9%E7%9B%AE%E4%B8%8B%E8%BD%BD%E5%88%B0%E6%88%91%E7%9A%84%E5%8E%9F%E5%9E%8B%20PCB%20%E6%9D%BF%E5%90%8E%EF%BC%8C%E7%A8%8B%E5%BA%8F%E8%A7%A6%E5%8F%91%E4%BA%86%E7%9C%8B%E9%97%A8%E7%8B%97%E8%B6%85%E6%97%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E7%A6%81%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%E5%AE%9A%E6%97%B6%E5%99%A8%E7%9A%84%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%EF%BC%9F%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3D%20%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%9D%BF%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BB%A3%E7%A0%81%20%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3CDIV%3E%2F*%20%E6%9D%BF%E5%88%9D%E5%A7%8B%E5%8C%96%20*%2F%3C%2FDIV%3E%3CDIV%3E%E6%97%A0%E6%95%88Board_Init%EF%BC%88%EF%BC%89%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%23if%201%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EDISABLE_INTERRUPTS()%3B%20%2F%2F%E7%A6%81%E7%94%A8%E5%85%A8%E5%B1%80%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWDOG-%26gt%3BCNT%3D0xD928C520%3B%20%2F*%E8%A7%A3%E9%94%81%E7%9C%8B%E9%97%A8%E7%8B%97*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWDOG-%26gt%3BTOVAL%3D0x0000FFFF%3B%20%2F*%20%E6%9C%80%E5%A4%A7%E8%B6%85%E6%97%B6%E5%80%BC%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EWDOG-%26gt%3BCS%20%3D%200x00002100%3B%20%2F*%20%E7%A6%81%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EENABLE_INTERRUPTS()%3B%20%2F%2F%20%E5%90%AF%E7%94%A8%E5%85%A8%E5%B1%80%E4%B8%AD%E6%96%AD%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E9%92%9F%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECLOCK_DRV_Init(%26amp%3BclockMan1_InitConfig0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_Init(NUM_OF_CONFIGURED_PINS%2C%20g_pin_mux_InitConfigArr)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F***%20SPI%20***%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ELPSPI_DRV_MasterInit(MLX%2C%26amp%3BmlxState%2C%26amp%3Bmlx_MasterConfig0)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F***%20LPIT%20***%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ELPIT_DRV_Init%EF%BC%88INST_LPIT1%EF%BC%8C%26amp%3Blpit1_InitConfig%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ELPIT_DRV_InitChannel%EF%BC%88INST_LPIT1%EF%BC%8CCHAN_0%EF%BC%8C%26amp%3Blpit1_ChnConfig0%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EINT_SYS_InstallHandler%EF%BC%88LPIT0_IRQn%EF%BC%8C%26amp%3BLPIT_ISR%EF%BC%8C%EF%BC%88isr_t%20*%EF%BC%890%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ELPIT_DRV_%E5%90%AF%E5%8A%A8%E5%AE%9A%E6%97%B6%E5%99%A8%E9%80%9A%E9%81%93%EF%BC%88INST_LPIT1%EF%BC%8C%E9%80%9A%E9%81%930_%E6%8E%A9%E7%A0%81%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F***%20%E8%83%BD%20***%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20can%20pal%20%E5%AE%9E%E4%BE%8B%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20!!!%20PE%20%E6%97%B6%E9%92%9F%E6%BA%90%E5%BF%85%E9%A1%BB%E6%98%AF%E5%A4%96%E8%AE%BE%E6%97%B6%E9%92%9F%20!!!%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_Init%EF%BC%88%26amp%3Bhscan_instance%EF%BC%8C%26amp%3Bhscan_Config0%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F*%20%E8%AE%BE%E7%BD%AE%E7%BC%93%E5%86%B2%E5%8C%BA%E9%85%8D%E7%BD%AE%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECAN_ConfigTxBuff%EF%BC%88%26amp%3Bhscan_instance%EF%BC%8CTX_MAILBOX%EF%BC%8C%26amp%3BTxbuffCfg%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emsg.id%20%3D%20HSCAN_ID%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Emsg.cs%20%3D%200U%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%B6%88%E6%81%AF%E9%95%BF%E5%BA%A6%3D8%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F***%20SBC%20%E6%8E%A7%E5%88%B6%20***%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%2F%2F%20%E8%AE%BE%E7%BD%AE%20SBC%20%E6%8E%A7%E5%88%B6%E5%BC%95%E8%84%9A%E8%BF%9B%E5%85%A5%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPINS_DRV_SetPins(STBN_PORT%2C%20STBN_PIN)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K118%E7%9C%8B%E9%97%A8%E7%8B%97%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AFS32K1%20SDK%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%88%99system_S32K118.c%E4%B8%AD%E6%9C%89%3CSTRONG%3EDISABLE_WDOG%3C%2FSTRONG%3E%E5%92%8Csystem_S32K118.h%E5%8F%AF%E7%94%A8%E4%BA%8E%E7%A6%81%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%9A%3CBR%20%2F%3E%20%2FSDK%2F%E5%B9%B3%E5%8F%B0%2F%E8%AE%BE%E5%A4%87%2FS32K118%2F%E5%90%AF%E5%8A%A8%2F%E7%B3%BB%E7%BB%9F_S32K118.c%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22DISABLE_WDOG%20system_S32K118.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22DISABLE_WDOG%20system_S32K118.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F280960i1EECA47F9095DFAB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22DISABLE_WDOG%20system_S32K118.png%22%20alt%3D%22DISABLE_WDOG%20system_S32K118.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%86%E6%88%91%E4%B8%8D%E6%98%8E%E7%99%BD%E4%B8%BA%E4%BB%80%E4%B9%88%E5%AE%83%E5%9C%A8S32K118EVB%E4%B8%8A%E8%BF%90%E8%A1%8C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%BD%A0%E7%9A%84%E5%8E%9F%E5%9E%8BPCB%E6%9D%BF%E4%B8%8A%E5%8D%B4%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E3%80%82%E4%BD%A0%E6%AF%94%E8%BE%83%E8%BF%87%E6%99%B6%E4%BD%93%E7%94%B5%E8%B7%AF%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8C%BA%E5%88%AB%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%BD%97%E5%AE%BE%3CBR%20%2F%3E--------------------------------------------------------------------------------%3CBR%20%2F%3E%E7%AC%94%E8%AE%B0%EF%BC%9A%3CBR%20%2F%3E%20-%20%E5%A6%82%E6%9E%9C%E8%BF%99%E7%AF%87%E6%96%87%E7%AB%A0%E5%9B%9E%E7%AD%94%E4%BA%86%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E2%80%9C%E6%A0%87%E8%AE%B0%E6%AD%A3%E7%A1%AE%E2%80%9D%E6%8C%89%E9%92%AE%E3%80%82%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%88%91%E4%BB%AC%E4%BC%9A%E5%85%B3%E6%B3%A8%E4%B8%8A%E6%AC%A1%E5%8F%91%E5%B8%96%E5%90%8E%E4%B8%83%E5%91%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%8C%E4%B9%8B%E5%90%8E%E7%9A%84%E5%9B%9E%E5%A4%8D%E5%B0%86%E8%A2%AB%E5%BF%BD%E7%95%A5%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E7%A8%8D%E5%90%8E%E6%9C%89%E7%9B%B8%E5%85%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E8%AF%B7%E6%89%93%E5%BC%80%E4%B8%80%E4%B8%AA%E6%96%B0%E7%BA%BF%E7%A8%8B%E5%B9%B6%E5%8F%82%E8%80%83%E5%B7%B2%E5%85%B3%E9%97%AD%E7%9A%84%E7%BA%BF%E7%A8%8B%E3%80%82%3CBR%20%2F%3E--------------------------------------------------------------------------------%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
