S32K1 attach gdbserver without reset
peacefulcarrot
I am trying to attach my debugger (SEGGER J-Link) to a running target to debug it. However, when starting the gdb server, the target seems to reset.
Steps to reproduce this issue:
1. Start SEGGER J-Link Remote Server
2. Start gdb server (in WSL2) using the following command: `JLinkGDBServerCLExe -device S32K144W -endian little -if SWD -speed auto -noir -noLocalhostOnly -nologtofile -TelnetPort 19020 -select IP=192.168.x.y -noreset -nohalt`
Observer behaviour:
When the command is run, the RESET pin is pulled down for 160ms. The running program is stopped (observed by the blinking led that stops). After ~4 seconds, the gdbserver is attached (> `Connected to target`) and the application starts again (led blinking). However, the application was reset, which is not as desired.
Any idea to why this would be or what I could do to find the cause? The reset reason seems to be SW reset.
The used MCU is a S32K144W on a custom board. Debugging etc works without a problem, the issue I am having is just that I cannot attach to a running target.
danielmartynek
HI @peacefulcarrot,
It is necessary that the MCU is in the unlocked state.
A special JLink script is needed, which can be found here:
https://wiki.segger.com/S32Kxxx#Attach_to_debug_session
JLink commander has to be called in following way:
C:\Programme\SEGGER\JLink\JLink.exe -JLinkScriptFile NXP_Kinetis_S32_Attach.JLinkScript
Then, the MCU is not reset, and access to all memory and registers is possible.
Please contact SEGGER support if you have any questions,
danielmartynek
HI @peacefulcarrot,
peacefulcarrot
Hi @danielmartynek ,
Using the script when starting the gdb server solved the problem.
`JLinkGDBServerCLExe -device S32K144W -endian little -if SWD -speed auto -noir -noLocalhostOnly -nologtofile -TelnetPort 19020 -select IP=192.168.x.y -JLinkScriptFile NXP_Kinetis_S32_Attach.JLinkScript -nohalt`
Thank you very much and have a nice day!
%3CLINGO-SUB%20id%3D%22lingo-sub-1888731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K1%20attach%20gdbserver%20without%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1888731%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20am%20trying%20to%20attach%20my%20debugger%20(SEGGER%20J-Link)%20to%20a%20running%20target%20to%20debug%20it.%20However%2C%20when%20starting%20the%20gdb%20server%2C%20the%20target%20seems%20to%20reset.%3C%2FP%3E%3CP%3ESteps%20to%20reproduce%20this%20issue%3A%3C%2FP%3E%3CP%3E1.%20Start%20SEGGER%20J-Link%20Remote%20Server%3C%2FP%3E%3CP%3E2.%20Start%20gdb%20server%20(in%20WSL2)%20using%20the%20following%20command%3A%20%60JLinkGDBServerCLExe%20-device%20S32K144W%20-endian%20little%20-if%20SWD%20-speed%20auto%20-noir%20-noLocalhostOnly%20-nologtofile%20-TelnetPort%2019020%20-select%20IP%3D192.168.x.y%20-noreset%20-nohalt%60%3C%2FP%3E%3CP%3EObserver%20behaviour%3A%3C%2FP%3E%3CP%3EWhen%20the%20command%20is%20run%2C%20the%20RESET%20pin%20is%20pulled%20down%20for%20160ms.%20The%20running%20program%20is%20stopped%20(observed%20by%20the%20blinking%20led%20that%20stops).%20After%20~4%20seconds%2C%20the%20gdbserver%20is%20attached%20(%26gt%3B%20%60Connected%20to%20target%60)%20and%20the%20application%20starts%20again%20(led%20blinking).%20However%2C%20the%20application%20was%20reset%2C%20which%20is%20not%20as%20desired.%3C%2FP%3E%3CP%3EAny%20idea%20to%20why%20this%20would%20be%20or%20what%20I%20could%20do%20to%20find%20the%20cause%3F%20The%20reset%20reason%20seems%20to%20be%20SW%20reset.%3C%2FP%3E%3CP%3EThe%20used%20MCU%20is%20a%20S32K144W%20on%20a%20custom%20board.%20Debugging%20etc%20works%20without%20a%20problem%2C%20the%20issue%20I%20am%20having%20is%20just%20that%20I%20cannot%20attach%20to%20a%20running%20target.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K1%20attach%20gdbserver%20without%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%3CP%3EUsing%20the%20script%20when%20starting%20the%20gdb%20server%20solved%20the%20problem.%3C%2FP%3E%3CP%3E%60JLinkGDBServerCLExe%20-device%20S32K144W%20-endian%20little%20-if%20SWD%20-speed%20auto%20-noir%20-noLocalhostOnly%20-nologtofile%20-TelnetPort%2019020%20-select%20IP%3D192.168.x.y%20-JLinkScriptFile%20NXP_Kinetis_S32_Attach.JLinkScript%20-nohalt%60%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20and%20have%20a%20nice%20day!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1889185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K1%20attach%20gdbserver%20without%20reset%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1889185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F234079%22%20target%3D%22_blank%22%3E%40peacefulcarrot%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EIt%20is%20necessary%20that%20the%20MCU%20is%20in%20the%20unlocked%20state.%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EA%20special%20JLink%20script%20is%20needed%2C%20which%20can%20be%20found%20here%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwiki.segger.com%2FS32Kxxx%23Attach_to_debug_session%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fwiki.segger.com%2FS32Kxxx%23Attach_to_debug_session%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EJLink%20commander%20has%20to%20be%20called%20in%20following%20way%3A%3C%2FP%3E%0A%3CP%3EC%3A%5CProgramme%5CSEGGER%5CJLink%5CJLink.exe%20-JLinkScriptFile%20NXP_Kinetis_S32_Attach.JLinkScript%3C%2FP%3E%0A%3CP%3EThen%2C%20the%20MCU%20is%20not%20reset%2C%20and%20access%20to%20all%20memory%20and%20registers%20is%20possible.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EPlease%20contact%20SEGGER%20support%20if%20you%20have%20any%20questions%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
