Hello All,
There is an error that occurred when I installed the S32K1 RTD Extensions.
Solved! Go to Solution.
Solved, using http://www.nxp.com/lgfiles/updates/Eclipse/APSW/S32DS_3.4 to install new software.
Thank you. But I can not find any package for offline use. There is only a .exe file for installed, could not be integrated in S32DS IDE.
Yes, but where is the archive file for RTD? I can not find it in NXP.com.
just click the .exe to perform the installation.
I have installed the SW32K1_RTD_4.4_1.0.1_D2202.exe. The installation process asks to select the EB directory, but no S32DS.
After that, I still can not create S32 RTD based projects.
Hi @Vasily_Wu
I have installed the RTD succeed ,but i can not choose this RTD as the sdk when i new a s32k144 project, can you help me? thank you very much.
i can not choose this RTD as the sdk when i new a s32k144 project.
