S32K fixed the RAM map the Flash Error
3,911 次查看
caesar_song
Hello,  Could you help to solve the problem that  my customer met,
My customer used S32K144 as the MCU platform,but they use inca software fixed the RAM map the Flash,but after the step, the Flash neither read nor write,I dont know ,what is wrong ,
other projects ,i used inca software to fix SPC5744 ,All things is OK,  I doubt the Inca is not use for theS32K? so what software can be used for fix S32K144
3,866 次查看
lukaszadrapa
I just answered the same question here:
https://community.nxp.com/thread/537258
Lukas
