1) There is no functional difference in the Secure Debug authentication sequence or security features between JTAG and SWD. Both interfaces access the same underlying debug and authentication infrastructure.
2) The choice is mainly related to pin count, board design and compatibility with debug or production equipment. SWD uses only two signals, while JTAG may be preferred for existing JTAG test infrastructure or scan-chain requirements.
3) SoC-400 does not provide additional Secure Debug functionality available only through SWJ-DP. SWJ-DP primarily provides flexibility to access the CoreSight DAP through either JTAG or SWD.
4) Neither interface is inherently more secure. SWD is generally convenient because of its lower pin count, while JTAG may be selected when required by existing manufacturing or boundary-scan equipment. For S32K3, both are valid Secure Debug interfaces.
