S32K SAI
S32K SAI
1,880件の閲覧回数
wanglijun
Is there an SW project example about the SAI module, and the example is related with DMA transfer?
タグ(1)
1,871件の閲覧回数
danielmartynek
Hello @wanglijun,
There is sai_transfer_S32K148 SDK example.
In the example, the transmitter uses interrupts while the receiver DMA.
Refer also to AN12202 Using Synchronous Audio Interface (SAI) on S32K148
https://www.nxp.com/docs/en/application-note/AN12202.pdf
