S32K Port_PCR
S32K Port_PCR
4,655 次查看
lihui1
About S32K Port_ PCR register , there are two bit about PE and PS. According user manual , it seems like this two bit are associated.
After testing , it is appoint that when PE is 1, PS is followed by 1 ; when PE is 0, PS isn't followed by 0.
In fact , it has no problem with the application , but we are worried about if there will be hidden dangers. So we wants to kwon why "PE is 0, PS isn't followed by 0" .
4,645 次查看
Senlent
Hi@lihui1
It says very clearly in below picture.
BR!
      Jim,
4,646 次查看
Senlent
Hi@lihui1
BR!
      Jim,
4,634 次查看
lihui1
Thank you . We had found there are something wrong in our test code.
