S32K Install Stack in S32 DS v5.0 failed
lluo
Hi , I am trying to install the following package in S32 Design Studio version 5.0:
And I got the following error:
The RTD that I am using is 4.0.0 D2311. Do you probably know what is missing in my setup and what needs to be done to resolve this issue?
Thank you in advance.
Senlent
Hi@lluo
I have reproduced your problem ,here is my solution:
"make sure you already installed FreeRTOS 10.6.0 version 4.0.0 package first."
You can find the below infos in SW32K3_TCP/IP-STACK_1_0_4_D2401_ReleaseNotes
Before installing the S32K3 1.0.4 TCP/IP stack package, you need to install:
- S32K3 development package,
- S32K396 development package,
- S32K3_S32M27x Real Time Drivers ASR R21-11 Version 4.0.0 package,
- SW32K3 FreeRTOS 10.6.0 version 4.0.0 package.
Senlent
Hi@lluo
lluo
Hi @Senlent ,
By uninstalling S32 Design Studio 3.5 and reinstalling the following packages suggested in the release note, now I can install stack in S32 DS v5.0 successfully. Thank you for the support.
