S32K Install Stack in S32 DS v5.0 failed
1,911件の閲覧回数
lluo
Hi , I am trying to install the following package in S32 Design Studio version 5.0:
And I got the following error:
The RTD that I am using is 4.0.0 D2311. Do you probably know what is missing in my setup and what needs to be done to resolve this issue?
Thank you in advance.
タグ(1)
1,888件の閲覧回数
Senlent
Hi@lluo
I have reproduced your problem ,here is my solution:
"make sure you already installed FreeRTOS 10.6.0 version 4.0.0 package first."
You can find the below infos in SW32K3_TCP/IP-STACK_1_0_4_D2401_ReleaseNotes
Before installing the S32K3 1.0.4 TCP/IP stack package, you need to install:
- S32K3 development package,
- S32K396 development package,
- S32K3_S32M27x Real Time Drivers ASR R21-11 Version 4.0.0 package,
- SW32K3 FreeRTOS 10.6.0 version 4.0.0 package.
2 返答(返信)
1,889件の閲覧回数
Senlent
Hi@lluo
1,826件の閲覧回数
lluo
Hi @Senlent ,
By uninstalling S32 Design Studio 3.5 and reinstalling the following packages suggested in the release note, now I can install stack in S32 DS v5.0 successfully. Thank you for the support.
